Old 10-05-2021, 01:12 AM #16
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Personally, I didn't give it enough thought, saw a sale and pressed Buy Now. I read the blurbs on both Opt-in and Duro Bumps' sites and went with what appeared the written guidance - shorter set for stock up to 2" and taller set for 2" and above. Not knowing what the future may hold, I went with the longer set. When I popped the rears in I also noticed the greatly reduced distance to the axle. The fronts didn't concern me. When I was out on some trails a couple weeks ago, I had a look under there at what seemed like full stuff and while the bump stop was super compressed and bulging, it didn't seem like the tire had much further to go up in the wheel well, anyway. Right now I'm not feeling like they are really that much of a travel-limiter with 5100s and 906s. It might not be the optimal setup, but I don't think it's horrible at this point. I have a lot more to learn and will take a closer look at the local OHV park on their obstacle courses soon....
Old 10-05-2021, 09:22 AM #17
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Originally Posted by Romeo1 View Post
So, I guess I’ll ask it here. Are there any contact issues with the shorter durobump on a 2” suspension lift with 2906 springs and 5160 Bilsteins? I wouldn’t mind moar articulation.
EDIT: We're running different shocks (5100 vs 5160), so it won't be a perfect comparison to your setup, but it will be close.
I’ll update this thread once I’ve got everything buttoned up and I’m able to test it out.
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 10-06-2021, 10:07 AM #18
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
I wonder if by going to the shorter bumps on a lifted setup if it could create a situation where the flex causes the drooped side to get the springs really loose? That would make sense.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 10-06-2021, 10:19 AM #19
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
That shouldn't happen if you are using the correct shocks for your springs. The extended length of the shock will (should) limit the droop of the axle during flex and should prevent the axle from over extending and losing the spring.
Old 10-11-2021, 10:41 PM #20
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Figured I’d do a quick update:
Installed the stock length durobumps on Thursday, just did a flex test real quick cause someone is coming to buy my 5.25’s tonight. Here’s the results.
Springs removed and full weight of vehicle on the bumpstops still have about 1” shock travel left on passenger and 3/4” on driver. If I notice it seems like it’s bottoming out which I don’t think it will I can just make some small 1/4”-1/2” spacers for the bumpstops.
Amazingly the 35’s don’t rub at all at full compression either. Although I have my rear upper control arms adjusted for my pinion angle.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 10-12-2021, 04:54 PM #21
Looks good! You may want to check the clearance of the tires with flexing too, since the wheel on the 'high' side of a flex can move up farther than it does with flat compression.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-12-2021, 06:05 PM #22
T4topher's Avatar
T4topher's Avatar
Thought about doing that right after I put the springs back in, lol.. Would be so much easier if I could use a forklift.. Not too worried though as it looked like there was a decent amount of room all around the tire except towards the front where it was only like 1/4”. If it rubs I’ll trim it as needed.
Old 12-01-2021, 02:11 PM #23
cl4Rk's Avatar
cl4Rk's Avatar
Update: installed the 3.5” DuroBumps. I haven’t really tested them yet but they look like they’ll be perfect for my application.
@Y2K_4X4
Old 12-01-2021, 10:52 PM #24
Romeo1's Avatar
Romeo1's Avatar
Be interesting to see what happens.
Old 12-06-2021, 02:30 PM #25
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Also curious as well... My current temporary LC shocks are too firm for me to even touch the bumps now that I've fixed my sway bar links...so I really have no idea what hitting them feels like sadly... The bumps that is.
Do they hit soft or hard?
Old 12-06-2021, 09:22 PM #26
Romeo1's Avatar
Romeo1's Avatar
They feel fairly soft unless you hit something extremely hard and fast. Even then, it still feels like pillows relative to the factory bump setup.
Go articulate it out and you’ll be able to feel it. It’s a gentle contact that kind of continues progressively for a ways on mine.
Old 12-06-2021, 09:31 PM #27
cl4Rk's Avatar
cl4Rk's Avatar
DuroBumps 5.25” VS 3.5" bump stops for 2" lift ?
Soft (at first) like @Romeo1 said, and then they firm up. This is by design with the progressive rated rubber used. I can squish the lowest part of them with my finger.
@Y2K_4X4
Old 12-06-2021, 09:57 PM #28
jross20's Avatar
jross20's Avatar
Haha... Yeah there's absolutely no way to simulate that with Land cruiser shocks on the rear. Things are wayyyy too stiff...lol.
See years ago when I had tundra shocks in the rear I also had rear sway bar links that were too long but I did not know it at the time... They kept hitting the lower arms which I took as the bumps being very hard...
So now here I am with shorter links but the Land cruiser shocks are too damn stiff... I'm using them temporarily until my Kings get back from a revalve
Really? Well hopefully I'll get the test that out when my Kings get back
durobumps , experience , lift , rubber , running
Do I need new bump stops with my 2.5" Dobinson's lift? mbm112 5th gen T4Rs 2 03-17-2021 06:07 PM
FS: 5th Gen 4Runner Durobumps Bump Stops F&R $203.00 Tuscon AZ Plastics guy For Sale: T4R Items 7 02-23-2020 10:16 PM
WTB: "Junkyard" Bump stops Karbyn For Sale: Suspension/Wheels/Tires 1 09-05-2017 02:16 PM
FS: "junkyard" extended bump stops robb1887 For Sale: Suspension/Wheels/Tires 8 04-21-2013 02:33 PM
