Old 09-21-2021, 10:36 AM #1
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
DuroBumps 5.25” VS 3.5" bump stops for 2" lift ?
So I have a set of 5.25" DuroBumps that I was going to install with my recent ~2" lift (Bilstein 5100 with OME 906s).
I know the website says the 5.25" are for a 2" lift, but they seem really tall to me. I know they're progressive rubber, so that should help. But I can't help but think that I'd be better off with the 3.5" DuroBumps.
Anyway, does anyone have any experience running the 5.25" and/or 3.5" DuroBumps with a 2" lift? Or maybe help me understand why the 5.25" might be right for my application?
Thanks!
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 09-21-2021, 12:45 PM #2
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
I had the same dilemma when choosing DuroBumps for my 2" lift.
I measured the clearance between the OEM bumpstops and the axle with the shock fully compressed - it was just touching on one side, and about 1/4" gap on the other. I then measured the OEM bumpstop height (I think it was about 2"), which meant that I needed something greater than about 2-1/2" when fully compressed, to avoid bottoming out the shocks with some margin.
I wasn't sure if the 3.5" DuroBumps would be tall enough, since I couldn't find any reference that gave the compressed height, but the 5.25" just seemed too long. So I figured that I'd rather get the 3.5" ones and add a small spacer if needed than get the 5.25" and have to cut them down to avoid constantly bottoming out on the bumpstops. Jason from Opt Offroad also suggested the 3.5" ones for my application.
I haven't driven it enough yet to know for sure, but I did put the 3.5" bumpstop in a vise and tried to compress it, it did not compress all that much - so I think it was the right choice.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 09-21-2021, 12:55 PM #3
If you have stock (or near stock) length shocks when the are compressed, get the shorter ones. If you have longer (LC, 4th/5th gen, etc.) shocks, get the longer ones.
You want to maximize travel whenever possible...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-21-2021, 01:34 PM #4
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Thanks!
Going through this as well, I had won a set of the 5.25’s from a Timmy the Toolman bbq a few years back. I just recently flex tested my suspension (old toytec bilstien/boss kit) and at full bump (bumpstops compressed) I have about 3”+ of shock travel left.. Ordered up some of the 3.5’s a week ago I think they will be perfect since they are only 1.75” shorter. If your unsure the best way to check is flex test by removing the rear coils.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 09-21-2021, 07:12 PM #5
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
I wonder if the risk of tire rub goes up with the shorter one? I should have looked the bottomed out side the other day when i took these. These are the longer 5.25 durobumps on 2” lift, 265/75 tires.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 09-21-2021, 07:30 PM #6
cl4Rk's Avatar
cl4Rk's Avatar
These photos are very helpful. I’m also running 265/75r16s.
@Y2K_4X4
Old 09-21-2021, 07:39 PM #7
cl4Rk's Avatar
cl4Rk's Avatar
Based on those photos, I may just install what I’ve got and cut them down or swap them out later if needed.
One last question: what’s the size/thread/pitch for the bolts I need for the 5.25” ?
(My bolts are long gone and so are my original OEM bump stops.)
Thanks! Super helpful as always!!
@Y2K_4X4
Old 09-21-2021, 08:24 PM #8
official vendor
official vendor
The bolts are M8-1.25mm, about 35-40mm long as I recall (they need to be longer than OEM bolts because the DuroBumps have a thicker section under the washer).
Old 09-21-2021, 08:40 PM #9
Romeo1's Avatar
Romeo1's Avatar
I’m going to assume that the passenger rear was bottomed out that photo. I didn’t actually look. I know we were teeter tottering basically on two wheels there, and my son and I were laughing that we need to get out and get a photo of it.
The eLocker made short work of the departure.
This old Toyota continues to just impress me with how capable it is for no more than is done to it.
Old 09-21-2021, 08:43 PM #10
Romeo1's Avatar
Romeo1's Avatar
Glad they helped!
Old 09-21-2021, 08:46 PM #11
Romeo1's Avatar
Romeo1's Avatar
One thing to add, I’ve taken some gnarly gnarly hits with this thing. Two or three of them that I had a feeling of dread as soon as things got settled back and the thought in my head of “great I surely just bent something in half just now.” I have anticipated carnage and taco/horseshoe shaped parts…..
I don’t advocate for people doing anything stupid. Please drive within your comfort and your ability. But the ability for these Durobumps to dissipate energy is just amazing. It gives me a little too much confidence sometimes and I probably hit things a little faster than I probably should.
Time for a long travel maybe????? Lol……
Old 10-04-2021, 02:37 PM #12
cl4Rk's Avatar
cl4Rk's Avatar
Just to update this thread: While I'm sure I'd probably be just fine with the 5.25" DuroBumps (especially after seeing @Romeo1 's photos), I spoke with Jason from OPT OFF ROAD again, and like with @Spiker Engineering , he confirmed I should go with the 3.5" DuroBumps for my application.
@Y2K_4X4
Old 10-04-2021, 07:12 PM #13
T4topher's Avatar
T4topher's Avatar
My 3.5’s just shipped out today! I want to flex test it after I install them but that’s a ton of work and I’m 95% sure they will be just fine.. lol.
Old 10-04-2021, 07:57 PM #14
Romeo1's Avatar
Romeo1's Avatar
So, I guess I’ll ask it here. Are there any contact issues with the shorter durobump on a 2” suspension lift with 2906 springs and 5160 Bilsteins? I wouldn’t mind moar articulation.
Old 10-04-2021, 11:50 PM #15
lawrencesam74's Avatar
lawrencesam74 lawrencesam74 is offline
Real Name: Samuel
lawrencesam74 is on a distinguished road
Real Name: Samuel
Just thought I would chime in although I haven't installed anything yet, but I'm going with 906's and Fox 2.0s for a 4th gen, so a longer than stock shock. I found a pair of 5.25 bumps and even though I should just be getting about 2" of lift I think for running a longer shock, I want to avoid over compressing so it seems like the longer bumps will give me that protection. Also gives me headroom for running a taller spring in the future.
lawrencesam74 is offline   Reply With QuoteReply With Quote
durobumps , experience , lift , rubber , running
Do I need new bump stops with my 2.5" Dobinson's lift? mbm112 5th gen T4Rs 2 03-17-2021 06:07 PM
FS: 5th Gen 4Runner Durobumps Bump Stops F&R $203.00 Tuscon AZ Plastics guy For Sale: T4R Items 7 02-23-2020 10:16 PM
WTB: "Junkyard" Bump stops Karbyn For Sale: Suspension/Wheels/Tires 1 09-05-2017 02:16 PM
FS: "junkyard" extended bump stops robb1887 For Sale: Suspension/Wheels/Tires 8 04-21-2013 02:33 PM
