UPDATE: see post #11 (reply #10) below:
https://www.toyota-4runner.org/3688745-post11.html
2000 SR-5 auto with J-shifter 4WD. My 4WD HI and LO worked normally (correctly) before the frame swap.
Current Situation:
- My front wheels are not getting power when I shift into 4WD (HI and LO) (no binding or wheel chirp on pavement).
- I do hear the actuator click
- I do see the 4WD dash light illuminate at the appropriate time.
- I do shift into the low gears (slow moving, high revving) when in 4LO.
Things I've already checked:
- The front propellor shaft spins freely while in 2WD.
- The front propellor shaft locks up and does not spin freely while in 4HI and 4LO.
- The frontmost VSV hose has vacuum while in 2WD.
- The rearmost VSV hose has vacuum while in 4HI and 4LO.
- Switching the VSV hoses prevents the 4WD light from illuminating at all (and does not send power to the front wheels), suggesting the hoses are currently in the correct places.
Question:
What's my next step in troubleshooting this?
New cv axles go in soon, the truck will be up on a lift. Thanks!!
