Old 11-20-2021, 11:23 AM #31
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
I’ve had luck cleaning switches like that in the past also. Just ohm it out to make sure your continuity is still intact.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 11:52 AM #32
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Originally Posted by Bad Luck View Post
I had a problem with my ADD position switch when I first bought my 4Runner. I removed the switch and cleaned it out with electronics/contact cleaner while depressing the "button" (it's more of a ball) and was able to get good continuity when depressed and no continuity when released. Might be worth a try if you haven't ordered parts yet and have a multimeter.
When you removed your ADD Switch for cleaning:
1. Did you need to replace the gasket? If so, do you happen to have the part number?
2. Did any gear oil drain out, so you had to top it off with a little new oil?
Just wanted to check on these things before removing the switch so I know if I need to get any parts/supplies.
Thanks!
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 01:10 PM #33
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Thanks!
I didn't replace the gasket and I didn't have any fluid come out when I removed them for cleaning. I did have to remove the transmission crossmember so I could sag the transfer case/transmission down enough to get to one of the position sensors on the transfer case.
Old 12-14-2021, 02:32 PM #34
cl4Rk's Avatar
cl4Rk's Avatar
SOLVED - Help troubleshooting 4WD issue for '00 with j-shifter
I just removed the ADD Switch, cleaned it with CRC electronics cleaner, tested it for continuity, and replaced it. I reused the gasket.
Unfortunately I forgot to test it BEFORE cleaning it, so I’ll never know if it was malfunctioning before I cleaned it. But it tested perfectly after I cleaned it. No continuity when the ball was extended/untouched, continuity as soon as I depressed the ball.
I had to remove the rear skid plate to access the switch with an adjustable wrench. Not sure what size the nut is since I didn’t have a socket that fit and there wasn’t really room for a ratchet up in there anyway.
I also cleaned the connector housing.
@Y2K_4X4
4hi , 4lo , 4wd , front , vsv
Troubleshooting Issue with 2012 csteranko 5th gen T4Rs 18 07-05-2021 09:48 PM
Avid 4Runner Boulder/Nederland Creeper NOW Member Here + Troubleshooting Deicer Issue Sbobby 5th gen T4Rs 2 05-14-2021 02:52 PM
Help with troubleshooting AC issue razzman1 4th Gen T4Rs 6 02-17-2017 08:56 AM
Troubleshooting starting issue DanSt4R 3rd gen T4Rs 7 11-29-2016 10:32 PM
Shifter Issue wutagoalie 4th Gen T4Rs 16 04-20-2013 12:49 AM
