Old 09-22-2021, 11:52 PM #1
stevew092984 stevew092984 is offline
stevew092984 is on a distinguished road
Off Road Bumper
I recently installed a custom off road bumper and I was wondering if you guys had any ideas about what I can do to the exposed areas. I'm a bit concerned about some of the wiring that is exposed and I think it could look better visually, just not quite sure how I might be able to do that. Any ideas are all welcomed. Thanks
Off Road Bumper-4runner1-1-jpg  Off Road Bumper-4runner2-1-jpg  Off Road Bumper-4runner3-1-jpg
stevew092984 is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 01:19 AM #2
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Start with trimming back this black plastic and cutting these brackets flush with the fender. You could also paint the rest of the visible radiator support black which might blend it together a bit better. Any loose wires I’d use some zip ties on other than that I wouldn’t worry much about the exposed wiring.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 01:31 AM #3
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Seems like it stops really short. Most tube style off road bumpers wrap around with the fenders to help protect them and deflect stuff away from the body and tires. Doing that also help hide all the stuff behind them. I'd do everything that T4topher said and see what it looks like
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 09:03 AM #4
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Yeah i agree, stops a bit short. Should be able to make it work though. Think about adding some perforated aluminum or wire mesh painted black
Old 09-24-2021, 12:31 AM #5
Maybe that's why this guy was selling it, lol. Thanks for the input guys, I like the ideas and I'll give it a shot. Cheers
Old 09-24-2021, 09:17 AM #6
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
Looks like he had plans to add more tubing to go around to the outside of the fenders but never got around to it
Bad Luck is online now   Reply With QuoteReply With Quote
Old 09-24-2021, 10:39 PM #7
MelodyRad's Avatar
MelodyRad MelodyRad is offline
Real Name: GundamDeathscythe
MelodyRad is on a distinguished road
MelodyRad's Avatar
looks like you got the wrong bumper if you are worried about exposed areas. This is your daily i'm assuming.
MelodyRad is offline   Reply With QuoteReply With Quote
Old 09-24-2021, 10:58 PM #8
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
The tube bumpers I build have very similar proportions. I trim the plastic fender liners all the way up to where they meet the inner fender, cut the bumper support off and rework it so it's only supporting the fender itself and doesn't hang down, remove the washer bottle and tuck the related wiring back up by the airbox, re-route the signal wiring and connect it all together into switchback bulbs in the corner lights, then I cut off all the excess sheet metal that hangs down in front of the tires on the core support. Everything below the headlight support bracket and to the outside of the main support where the body mounts are gets scrapped.
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
bumper , exposed , ideas , road , visually
Off Road Bumper?? hdhp65 4th Gen T4Rs 7 07-24-2020 09:26 AM
WTB Off road Bumper ~800 dgherfurth Want to Buy/Trade 0 03-26-2017 07:12 PM
WTB 4th Gen (03-05) OFF ROAD BUMPER redbull9944 Want to Buy/Trade 1 11-07-2013 02:38 AM
