Old 09-24-2021, 08:04 PM #1
HiluxChuck's Avatar
HiluxChuck HiluxChuck is offline
HiluxChuck is on a distinguished road
HiluxChuck's Avatar
Question Tightening crankshaft bolt
Hi all
I know that using the special tool and a 250+ft/lb torque wrench is the correct way to reinstall the crank bolt but that's not an option for me.
I've decided to just impact it on with some blue Loctite.
Before I do, I was looking for some advice on what angle roughly to turn it to from snug. Can anyone give me a rough idea, like 120 degrees for example?
My impact does 400ft/lb on second setting. Just looking for ballpark advice.
HiluxChuck is offline   Reply With QuoteReply With Quote
Old 09-24-2021, 08:07 PM #2
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
I tried making my own special tool and wound up cracking the balancer on one of mine like 15 years ago. I've done it 3 times since and I just used an impact. Never had an issue and 2 of those I put another 100k miles on.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 09-24-2021, 08:11 PM #3
HiluxChuck's Avatar
HiluxChuck's Avatar
That's encouraging thanks
Just scared of overtorquing it because my impact is a beast haha. Will 400ft/lbs get me into trouble if I over do it? I know it's a long shot but if anynone remembers how far it turns that would be a huge help :P
Old 09-24-2021, 08:17 PM #4
Strip the threads on the crank and you're in a world of hurt yes. Maybe get your hands on a less crazy impact. I think my 30 year old craftsman was rated at 300 foot pounds when new. And I'm still using it! And I wrench for a living.
Old 09-24-2021, 08:28 PM #5
HiluxChuck's Avatar
HiluxChuck's Avatar
Yes, that's probably the smart option. Will go get a mid torque and save the high for other stuff.
Cheers
Old 09-24-2021, 08:38 PM #6
TravThePro's Avatar
TravThePro TravThePro is offline
Real Name: Travis
TravThePro is on a distinguished road
TravThePro's Avatar
Real Name: Travis
Originally Posted by HiluxChuck View Post
Hi all
I'm not saying this is the solution to your answer, but you might get to a much safer number by doing something like using extensions. Here is a video of torque test channel trying it out with their guns and showing their results. Best wishes. https://www.youtube.com/watch?v=XYavlJY_5Ks
1996 T4R
TravThePro is offline   Reply With QuoteReply With Quote
Old 09-24-2021, 08:44 PM #7
HiluxChuck's Avatar
HiluxChuck's Avatar
Thanks, I would use extensions or a torque stick if there were more space
Old 09-24-2021, 10:27 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
@RandyBobandy and I just had to use a 8ft pipe and a camshaft holding tool on the flexplate on a v6 in and engine stand to get a harmonic balancer off.
We actually used the harmonic balancer tool and ripped the homonic balancer center off. So yes you can over tighten the crankshaft pully bolt. Thankfully the threads are good. So it's best to torque these properly.
By looks of it, I need to replace the key in the crankshaft as I can see at some point it slipped hence why it probably was over tightened.. I just wanted to share our experience.
Old 09-24-2021, 10:44 PM #9
HiluxChuck's Avatar
HiluxChuck's Avatar
Thanks, I'll keep that in mind.
In this case, it has never been off in 17 years and hopefully, will be the only time
Old 09-25-2021, 09:20 PM #10
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I think you probably are on this but be sure to use a brand new crank pulley bolt. The immense amount of torque needed weakens the threads considerably that re-using it is not recommended.
326WHP 347TQ
Old 09-25-2021, 09:25 PM #11
HiluxChuck's Avatar
HiluxChuck's Avatar
Thanks, yeah I wanted to but called the dealer to order one and he said there is none nationwide and has to order in from Japan which can take 1 to 2 months to get here.
He also said the dealers reuse 99% of them and only replace if damaged. Seems most of them are reused and impacted on from the research I've done on it.
Cheers
Old 09-26-2021, 07:31 AM #12
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Try mcgeorge Toyota, they had one to me within a week, if not partsouq has them and will probably get it to you even faster
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 07:29 PM #13
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
It's like a 16mm bolt, it ain't going to strip or break. Just crank it on tight and bump it a couple of times. I do this for a living and have changed about 1000 timing belts. Always have reused crank bolts, never broke or stripped one in 35 years.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 07:35 PM #14
HiluxChuck's Avatar
HiluxChuck's Avatar
Sweet, that's what I wanted to hear haha.
Cheers
Old 09-27-2021, 10:06 AM #15
I’ve always reused my old bolt. Never a problem.
400ft/lb , advice , bolt , impact , setting
Crank Bolt Tightening dnath28 3rd gen T4Rs 60 07-06-2016 07:18 PM
3.0 Crankshaft Bolt theking11863 Classic T4Rs 3 05-06-2016 11:07 AM
Panhard drop top bolt over tightening awareness JWaldz Toytec Lifts 0 07-22-2014 12:33 PM
22r crankshaft bolt size ronnie4 Classic T4Rs 1 04-20-2007 12:09 PM
The secrets of bolt tightening Thai Maintenance/Detailing 15 03-06-2004 12:14 PM
