The black box is Port installed USDM, the 99-02 should have the immobilizer for limited models and maybe others, which has the option you're after, you seem to be missing the last -lock step in your description to enter functions setup AFAIK, if your battery is low or weak you will need to charge it up before hand or put a charger on while doing this, and with the hood closed as there is a security sensor for the hood latch aswell.
