Old 09-26-2021, 09:01 PM #1
D'arce D'arce is offline
D'arce will become famous soon enough
new axle seal leaking...FIXED
I did new bearings and seals about 3 months ago. 50 miles after install I noticed a small amount of oil on the inside of the wheel. I took the drum off, cleaned it and the shoes as best I could and unclogged the breather. I have about 2000 miles since then. Now all of a sudden the wheel is coated in oil.
If I pull the axle and put in a new seal, is it true that the oil will wash out the bearing?
1996 4Runner with a 3rz-fe, e-locker and 5spd
2005 Passat TDI 5spd swapped
1997 E350 4x4 7.3 Powerstroke
D'arce is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 09:21 PM #2
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
my 2000 was leaking when I got it and yes the bearings were washed out. turn the bearing once you pull the axle. if they turn like raw metal on metal then yes they are washed out.
make sure you do the grease test when you re-install, I have done them on 3x different trucks now and I have not had a leak. I did miss the spacer one time and had to reset the position so it would contact the seal in the correct location.
timmy the tool man has a great rear oil seal video. in the end if the grease test works you will not leak rear gear oil. I'm going to guess you new bearings are probably still ok.
Old 09-26-2021, 09:46 PM #3
Thanks, I hope so and I will see how it spins. Definitely not going to drive it until I get it fixed. Are there any dimensions to measure off the bearing face to see if the retainer is in position?
If there are no dimensions to reference I'll certainly do a grease test as you suggest.
Old 09-27-2021, 09:22 AM #4
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Get under the truck and make sure the breather valve isn't stuck. If it's stuck, try to spin it around so it un seizes. Typically when the seal goes out and makes a mess inside the drums, it contaminates the brake pads in the process and you have to replace them.
2000 4Runner Limited 4x4 V6
Old 09-27-2021, 10:06 AM #5
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Sounds like you have entered, and become stuck in the Rear Axle bardo. The navigation of this bardo marks a critical stage in your transcendental 3rd gen ownership journey. Close family members should take turns reciting incantations from the Service Manual of the Factory during this time, and leave offerings of Brakleen and OE seals at your side.
Rear Axle Seals: The Ultimate Information and Replacement Thread (3rd gen)
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 11:06 AM #6
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Some have repacked the bearings with new grease with success, I'd check it. Mine had just the littlest oil weep into the ABS cavity and my bearings were washed grease free. Yours likely are now too.
This axle seal is an exact science. Watch Timmys video, read the DrCoffee thread carefully. It is possible to do this job yourself but the measurements and process have to be precise to get success. There is only about +/- 1mm of room for error on the retainer positions. Gotta get it right or its going to leak. And use new OEM seals from the dealership.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 02:58 PM #7
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
I had a re-leak after doing mine. I ended up getting new retainers, then when I pressed them on, I spread a little FIPG around the axle shaft that would fill in any micro scratches on the axle itself. I also spread some FIPG around the axle housing where the seal is pressed in to make sure nothing was working it's way around that way. About 10k miles since then, many of them very hard (Seattle>Cabo>Seattle) and no problems.
I think it was on Timmy's last video about doing the seals where he recommended not reusing the retainers.
Hopeless Diamond is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 04:08 PM #8
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I had to do the same thing for my left rear axle seal.
For anyone considering doing this, make sure you are using an FIPG specifically formulated for gear oil if you decide to go this route and new inner retainers that are flipped. Sharpie/grease test the retainer location soon before the FIPG sets up. I also smeared a bead on the inside edge of the inner retainer where it meets the axle shaft for good measure and waited the correct cure time before refilling my differential.
Old 10-01-2021, 04:14 PM #9
Make sure to replace your diff breather, or at least pull it and test by blowing through it. A bad breather can blow oil through the seal. I've been using dino oil in the rear diff since I did mine instead if synthetic I had been using. The dino oil seemed to fix the slight leak from the half botched press work the axle shop I took the half shafts to. Their first attempt was totally botched, wasn't going to be a third attempt. It's been ok with Lucas conventional 75W-90.
99 SR5 v6 4WD
11 SR5 v6 4WD
Old 10-01-2021, 04:41 PM #10
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Make sure the springs that hold pressure against the axles are in the seal properly and not broken. Is this what y'all mean by retainers?
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 05:43 PM #11
Real Name: Patrick
Real Name: Patrick
No. The solid pieces that are pressed onto the axle shaft are the retainers. The inner retainer is what the axle seal rides on completing the seal.
Old 10-05-2021, 08:04 PM #12
So I've got an update. I pulled the leaking axle shaft out and about 1/4 cup of pretty nasty oil came out with it. I was thinking this isn't good. Set the axle aside and noticed a hump of metal shavings built up on the ABS sensor. Well shoot....something obviously went sideways with this install. I grease the retainer and slide the axle back in. Tighten two bolts to pull it tight and I took a peak through the ABS sensor hole. I didn't even bother removing the axle to see the grease mark afterward. I pulled the other sides ABS sensor and the exact same thing.
I can see why its leaking but I don't understand where the metal came from. This is of ultimately my fault. I didn't check the seal was riding on the retainer before putting it into service. The fellow that pressed on the parts sure talked a big game. I'm going to stop by and see him tomorrow after work.
Old 10-24-2021, 07:12 PM #13
I just wanted to update the thread as fixed. I purchased the tool (from donald-the-bonald) off ebay and a 20 ton press from harbor freight. Followed Tim's second video and it went smooth. The shop that I had press on the bearings originally just guessed at the location. They had pressed them on so far that I could not get the removal tool underneath to remove them so I had to cut them off. Kind of a pain but all's well that ends well. The tool was top notch and had everything I needed.
Old 10-29-2021, 12:33 AM #14
cas5259 cas5259 is offline
cas5259 is on a distinguished road
This is why I’d rather buy the tools and do it myself, then I know it’s done right the first time. This job was a real pain for me cause it’s tough to setup the axle in the press by yourself. Anyways, glad you got it figured out.
To the shop guys defense, he’s going to be looking at a manual or something, no way he reads forum posts for tricks like flipping the retainer while working flat rate - assuming it’s not a dealer with access to TSB’s and part revision info.
cas5259 is offline   Reply With QuoteReply With Quote
Old 10-29-2021, 11:34 AM #15
nissanh nissanh is offline
I did it by my self too. Donald-the-bonald and HF press. Did the sharpi test as Tim suggested.. all is good. I pulled the ABS sensors out a week ago after 10 months of repair and glad to report those ABS tone-ring chambers are dry!
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
axle , miles , oil , seal , wheel
cv axle seal leaking again Mikep. 4th Gen T4Rs 5 12-08-2014 11:13 PM
Does this look like axle seal is leaking? AZ4runner08 4th Gen T4Rs 12 02-27-2014 09:36 PM
Which axle seal is leaking? Jon 3rd gen T4Rs 7 07-19-2013 01:36 PM
Axle seal leaking again?? thebrandon 3rd gen T4Rs 7 06-27-2012 03:50 PM
