Old 09-28-2021, 02:03 PM #1
FabMMoi FabMMoi is offline
FabMMoi is on a distinguished road
Clock spring?
Hi all,
After a few months without issue here's the new one: my horn stopped working, and the annual MOT is coming up.
  • Tested the cruise control: won't work (but I never used it in 3 years so...)
  • Hazard lights work
  • Fuse is fine
Didn't know how to do:
- test the ground or the horns on the battery
- test the ECU
- open the steering wheel and test the switch
I wonder if that's enough diagnostic at this point, but I've read the clock spring might be the culprit with these symptoms, does that seem correct?
Now, as usual getting parts to the UK for the good ol' Runner is a bit tricky, so I'm trying to find the right part number for the clock spring, as it seems the airbag connector is different pre and post 96. My car is a 96 Limited auto, and all the 84306-35010 or 84306-35011 I find on eBay seem to have the post-96 airbag connector, is that wrong? What would be the proper part?
note: I couldn't find a good exhaustive part catalog as PDF to print and keep at home, if anyone has a good link...
Thanks!
FabMMoi is offline   Reply With QuoteReply With Quote
Old 09-28-2021, 04:50 PM #2
phattyduck phattyduck is online now
Thanks!
ToyoDIY.com Make an account to see the pictures.
Since the specifics of the Hilux Surf vs. 4Runner, etc. are a bit fuzzy to history, you'll want to start there, I think. You can likely find compatible parts on other similar year Toyotas if you know what you are looking for.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 09-29-2021, 04:02 AM #3
Thanks! It confirms I need a 84306-35010 for my car... however both types of airbag connectors seem to come up with that same code (could be an oversight from the sellers?) so I'd like to make sure and get the right thing.
Among everyone who had to deal with that issue (seems like a lot), would you have pictures of the airbag connectors (pre and post 96') you could share here?
Diagnostic-wise, what do you guys think? Should I perform any of the additional steps mentioned above? (unfortunately couldn't find a tech write up about that on ToyoDIY)
Old 09-29-2021, 05:44 AM #4
(for reference: talking about that topic How to install a Clock Spring a.k.a. Spiral Cable.)
and here's the issue: 84306-35010 parts all seem to have the 98' airbag clip (right) instead of the 96' (left), hence probably not compatible with my car
edit: looks like there might be a type A and type B for the same part code?
Clock spring?-84306-35010-plug-jpg  Clock spring?-downsized_0510011756-jpg  Clock spring?-8430635010-cover-png
Old 09-29-2021, 08:09 AM #5
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
Clock spring?
i replaced my steering wheel with one from a 96 and when i did i had to replace the clock spring or it wouldn't work. I can tell you they're different, but i didn't take any pictures unfortunately
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 09-29-2021, 08:27 AM #6
Thanks, yes I think I can confirm this type A / B thing for the airbag clip, now I need to find a place that sells the type A and ships it to the UK. I probably should open my steering wheel and check it's type A indeed (never know if the previous owner might have changed it in the first 17 years of the car's life).
Any link to a reliable seller would be awesome, thanks in advance! :-)
Old 09-29-2021, 08:32 AM #7
spartacus's Avatar
spartacus's Avatar
Please Wait... | Cloudflare is pretty reliable source from UAE.
Old 09-29-2021, 10:17 AM #8
Thanks, tried a search there before, unfortunately they only have 1 part available among the 3 possible, and it's a type B (also, expensive)
Old 10-12-2021, 12:48 PM #9
Was able to find a second hand clock spring of the right type on Ebay, horn's back
clock , good , part , spring , test
Cincinnati: OEM clock spring phishtaco For Sale: T4R Items 0 03-14-2021 09:41 AM
Clock spring dudes4runner 3rd gen T4Rs 3 04-09-2020 11:40 AM
Clock Spring DIY petron5000 5th gen T4Rs 5 12-11-2019 06:04 PM
WTB: 3rd gen clock spring alpa_chino For Sale: T4R Items 10 11-17-2015 04:59 PM
clock spring? 152 Sumo 3rd gen T4Rs 4 05-03-2011 11:17 AM
