Old 09-30-2021, 03:38 PM #16
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by Yung_Ji View Post
Just ordered Denso MAF Sensor, and I will take a look for leaks in that area! Did you get it smoke tested or just used a carbon cleaner spray??
Just listen to the engine. Do it upon a cold start so if the carb cleaner hits the exhaust pipes it won't combust. Start it up and open the engine bay. Just listen for the engine tone to smooth out and fan to slow down. Then just spray on every vacuum hose end as well as the cracks in the the intake 'accordion' pipe. You'll know if you get it, the engine will either rev up or down quickly as soon as the carb cleaner hits the leak and then return to normal. Then replace the offending part. Any vacuum hose can be matched by an auto parts store but the intake may not be carried by them.
326WHP 347TQ
Old 09-30-2021, 03:39 PM #17
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Interesting, I never heard about this key sequence thing on the 3rd Gens… Anyone else know anything about this?
Jakeepoo3 has a 2010 4Runner which is a 5th gen. There may be a key sequence for him, but that would not apply to 3rd gen vehicles.
Old 09-30-2021, 06:45 PM #18
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
You're right about the generation difference. I didn't clarify. It took me a whole day browsing through the internet to find it after trying all the other methods. There's a video on YouTube that describes the procedure. I can't remember how I found it. The guy was in a Toyota car. He said that it would work on most Toyota vehicles. I didn't think it would work but I had already tried all the other stuff so I did it. It worked! Remember when you do get the relearning process started to let the truck idle for like ten minutes with all your accessories off. Then go through every gear in 2wd, 4wd, and 4lo and let idle for a few minutes. I drive mine like a maniac and give her hell for a hundred miles or so to learn my style. Crazy computers. Good luck!
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 09-30-2021, 07:07 PM #19
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Actually I found it. Here's the link. Hope this helps you get running properly!
How to reset idle on ANY Toyota car! - YouTube
Old 10-01-2021, 02:30 PM #20
Real Name: Jerod
Real Name: Jerod
It is for a 5th Gen. There's very few key sequences for our 3rd Gens and only for late year production vehicles. Too much thinking power for our archaic ECUs
326WHP 347TQ
Old 10-01-2021, 02:40 PM #21
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Did you watch the video on the link??
Old 10-02-2021, 11:17 AM #22
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
I replace the MAF o-ring after a few cleanings as insurance, or if it looks jacked up. Dunno if an old one would cause a vac leak but the part # 90099-14141
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 10-02-2021, 02:24 PM #23
Yung_Ji Yung_Ji is offline
Yung_Ji is on a distinguished road
Quick update guys,
Went to a mechanic to get it smoke tested for vacuum leaks and we were not able to find any.
My Denso MAF Sensor arrived and I replaced it and reset the ECU. I took it for about a 30 mile drive mostly freeway to recreate the high RPM acceleration scenario which triggered the P0171 code. I had my OBD Scanner feeding live data and it looks promising. Short and long term fuel trims never exceeded +5.5% even at 2500+ RPM accelerating on to the freeway. Engine feels much more responsive at acceleration at higher speeds as well. MAF reads around a nice 3.43 g/s at idle.
I hope this was the fix and I am out of the woods. I will check in for another update after 100-150 miles or so! Wish me luck guys and thanks for being an amazing and supportive community!
Yung_Ji is offline   Reply With QuoteReply With Quote
Old 10-05-2021, 05:57 PM #24
wrench.n.wheel's Avatar
wrench.n.wheel wrench.n.wheel is offline
wrench.n.wheel will become famous soon enough wrench.n.wheel will become famous soon enough
Quick update guys,
Do you have the part number for the sensor and what year is your rig?
'99 Millenium Silver SR5 | 5.29 Nitrogears/ARB lockers | 35s | Supercharged
Build Thread
wrench.n.wheel is offline   Reply With QuoteReply With Quote
cel , cleaned , fuel , maf , sensor
P0171 - System Too Lean Bank 1 clanofwolves 3rd gen T4Rs 57 09-05-2023 10:23 AM
P0171 Lean Bank appears and disappears Tundra9er 3rd gen T4Rs 12 08-29-2023 09:14 AM
P0171 Lean bank 1 Question jhueter 3rd gen T4Rs 43 08-21-2023 09:48 PM
P0171 - System Too Lean (Bank 1) nasdamus 4th Gen T4Rs 15 06-12-2019 03:40 PM
P0171 Code - Lean Bank 1... Help? jpontius 3rd gen T4Rs 5 02-23-2013 11:00 AM
