The machines are always talking to you. You just have to listen and pay attention. Sounds and smells are part of it. Gauges are giving you info.
If you see a puddle underneath it’s time to investigate.
It’s all part of a learning curve that most people can’t be bothered to learn these days because it interrupts book face and TikTok time…….
Back when I was a professional mechanic the joke used to always be that we became mechanics because we were too poor to pay other people to work on our cars….lol..
You don’t, in my opinion, I need to uncork the cooling system or check the oil every five minutes. You can if that is what you choose to do though. And it certainly doesn’t hurt provide if you don’t damage the radiator cap in the process. Most automatic transmissions require the system to be running to check fluid level.
That said, I’m also at the point, that strictly as creature of habit I always glance underneath the vehicle as I walk up to it to from a distance( it takes 2 nano seconds) see if somethings leaking. I can tell by the exhaust color and smell if it’s burning oil or coolant. If it’s not leaking, and it’s not getting burned, odds are it’s where it belongs. Same goes for differentials and transmissions. Provided there’s no leaks, and nothings wet under the vehicle, the fluid is probably where it belongs.
Until you develop that sense though, yeah, you should probably visually check everything.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
