Old 09-30-2021, 08:45 PM #16
Thepedigree13 Thepedigree13 is offline
Thepedigree13 is on a distinguished road
Also factor in alignment is you lift the front, and plan on your cv axles throwing grease from torn boots.
From my experience these older rigs were happy where they have been, and get disturbed even with a 2" lift.
2016 TE (WIFES)>Stock with KO2's, SW sliders
2001 Sport (MINE)>FJC front coils/C59-137 rear 5100's, 265/75r16 g003
2013 Mazdaspeed3 (MINE)> bolt ons and tune
Thepedigree13 is offline   Reply With QuoteReply With Quote
Old 09-30-2021, 10:07 PM #17
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
I second this. Especially since your rig has 250k+ things that have been in place for a while won't like a different angle.
Have you replaced the lower ball joints at all?
If not I would hold off on the lift till you can get those done. I did mine at 205k and they were still fine but better safe than sorry, especially with that failure, because at that point your not talking about sitting on the side of the road waiting for the tow truck, your talking about body damage and pretty much having the truck be totaled out not to mention possible bodily injury
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 09-30-2021, 10:42 PM #18
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
i don't know when they were done. the guy who owned it before kept up on repairs pretty religiously, so i'm sure they're okay for now.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 08:51 AM #19
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
If you don't know when they were replaced then you should replace them with OEM. I get it that you have a limited budget, but a lower ball joint failure will cost you exponentially more than the cost of new lower ball joints. If you need any examples of what can happen: site:toyota-4Runner.org/3rd-gen-t4rs/ lower ball joint failure - Google Search
Old 10-01-2021, 10:31 AM #20
Budget Friendly Rear Springs?
yeah, likely will, i know a guy who can get me some oem ones for like 242 OEM. is that a good price?
281k Miles
Build Thread
Old 10-01-2021, 01:09 PM #21
Real Name: Rich
Real Name: Rich
When I did mine I got em for 106 a piece at Mcgeorge Toyota online
Sent from my SM-G781U using Tapatalk
Old 10-01-2021, 01:20 PM #22
do you have a link? the ones i can find are 160 each
281k Miles
Build Thread
Old 10-01-2021, 01:34 PM #23
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
4334039465 - Toyota Joint assembly, lower ball, front left. Suspension, brakes, failed | McGeorge Toyota, Richmond VA
Toyota 4Runner Joint assembly, lower ball, front right. Suspension, brakes, failed - 4333039585 | McGeorge Toyota, Richmond VA
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 04:23 PM #24
Real Name: Patrick
Real Name: Patrick
It's highly recommended to replace the lower ball joint bolts when you replace the lower ball joints. Part number 90080-10066 (8 total for both sides) (37 lb/ft of torque).
Old 10-01-2021, 07:15 PM #25
TW44LR's Avatar
TW44LR TW44LR is offline
TW44LR will become famous soon enough
TW44LR's Avatar
Originally Posted by Spiker Engineering View Post
I ran the 5th Gen springs with stock length shocks, no issue with them falling out at full extension.
As for "lift", that term is often misused as the 3rd Gens have different starting heights depending on the year. So what may give a 1" lift on a '98, may give 2" lift on an '01.
For my '97, putting in the 5th Gen springs raised one side by 3/4", and the other by 1-1/4". In comparison, 2906's gave a 2" lift.
Gotcha currently running the fj80 front springs in the rear with extended length shocks and thinking of changing it up but I haven’t decided yet.
TW44LR is offline   Reply With QuoteReply With Quote
budget , lift , sag , springs , vin
Budget friendly dashcam Tbasse01 5th gen T4Rs 12 01-21-2021 07:29 PM
Budget Switch Pros setup and other budget options for switching/lighting? trailtruck Engines / Suspension / Wheels / Tires / Audio / Accessories 1 12-04-2019 07:44 PM
WTB: Budget friendly 3rd gen 4runner lift SO UT Jwallace98 Want to Buy/Trade 6 09-03-2017 03:23 PM
Best 4runner friendly online parts store ColoradoMTNlivin 3rd gen T4Rs 1 10-24-2011 11:47 PM
