Old 09-30-2021, 12:00 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
What hosing should I get for the wiper fluid line
I found out that the line that provides wiper fluid to the rear window sprayer is cracked where it runs under the passenger side door sill. Its leaked everywhere, probably done in by the high antifreeze ratio I use in the winter.
Anyone know the hose diameter that Toyota used? And should I worry about what sort of plastic its made out of?
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 09-30-2021, 03:17 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Cut a small section off and take it into your local auto parts store to find the correct size. Any rubber hose will be fine.
Old 09-30-2021, 11:12 PM #3
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
The inner diameter is the important measurement on the replacement hose. Recently I looked locally for replacement hose for the washer lines under the hood. There was no exact match for the hose, but I found a thicker hose that had a very close I.D. and used that. Hopefully the auto parts stores near you have a better selection than the ones near me.
pluton is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 10:35 AM #4
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
How hard is it to access the length of the line?
I know the hose runs under the front and rear passenger door sills, but I haven't seen how it connects to the spray nozzle or the reservoir. Should I just replace the damaged section?
antifreeze , fluid , high , line , wiper
TX: Misc 3rd gen items - ss line / spacers / rear wiper tv4184 For Sale: T4R Items 8 08-28-2020 01:24 AM
wiper fluid indicator 1974 FJ40 3rd gen T4Rs 20 11-01-2016 04:38 PM
Trans fluid over line littlehandegan 3rd gen T4Rs 2 11-08-2013 07:32 PM
Tranny fluid line broke doubleA 3rd gen T4Rs 3 11-30-2010 04:00 PM
Wiper fluid motor tahoe22 3rd gen T4Rs 0 11-26-2010 12:23 AM
