Old 09-30-2021, 12:23 PM #1
garn79's Avatar
garn79 garn79 is offline
Real Name: Jeff
garn79 is on a distinguished road
garn79's Avatar
Real Name: Jeff
Whats Compatable? 99sr5 vs '00Ltd
really need some input here perhaps @phattyduck @TheDurk etc any help appreciated and time is of essence..
mine: 99 sr5 4x4 auto 3.4
donor: 00Ltd 4x4 auto with elocker 3.4
i have an opportunity to grab some parts and wondering whats interchangeable mostly with electronic stuff or anything.
i really do not know what i should be looking at? brake booster ecm etc??
what big ticket items should i grab? elocker already gone. Please understand its rare where i live to get parts accessible like this.
garn79 is offline   Reply With QuoteReply With Quote
Old 09-30-2021, 12:41 PM #2
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is a jewel in the rough Team_Jake is a jewel in the rough Team_Jake is a jewel in the rough
Team_Jake's Avatar
Besides the e-locker, the only powertrain difference between the two will be transfer case. The 99-00 Ltd transfer cases are all multi-mode transfer cases, basically it's the same as the j-shift transfer case you already have but with an additional AWD option. If that is something you'd like, grab the transfer case, 4WD ECU (near the driver footwell), wiring harness, both front & rear driveshafts, and the gauge cluster (with the light-up 4WD/AWD indicator).
Some other things you may be interested in - power seats, leather seats, wood trim (it may not be your taste, but it's valuable if it's in good condition), and the auto-climate control (not really that desirable, but it is nice seeing the outside air temp with it).
Nearly everything else is exactly the same between the two vehicles, so if there's anything else broken, worn, or not working properly, this is a good chance to find a replacement part.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 09-30-2021, 03:22 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has much to be proud of Bad Luck has much to be proud of Bad Luck has much to be proud of Bad Luck has much to be proud of Bad Luck has much to be proud of Bad Luck has much to be proud of Bad Luck has much to be proud of Bad Luck has much to be proud of
Real Name: Patrick
Drive shafts will be different lengths. Front differential (if it's still there) will most likely be a different gear ratio than your current diffs. Transfer cases and supporting control modules/wiring will be different. Everything else mechanical is the same.
HVAC controls and case are different. All other trim pieces and seats are interchangeable.
2000 Limited V6 Auto E-Locker For Sale https://www.toyota-4runner.org/for-sale-vehicles/303103-fs-3rd-gen-4runner-hot-springs-ar-$8k-obo.html
Old 09-30-2021, 07:07 PM #4
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
There's surprisingly little that is exactly the same as your SR5 but there's a handful of stuff that's always in demand.
Headlights
Foglights
Center console and ebrake lever and mount
Tan steering wheel
Leather seats and door panels (inside door handles also are different)
Anything woodgrain, I.e. center bezel, shifter surround, window switches, gauge cluster trim
Working climate unit
Overhead console
Rear hatch
Other things are sellable but in less demand
Ecu
Engine harness
Excellent condition interior pieces, mostly rear cargo area, door sills, dashpad
Other lights
Working sunroof unit
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 08:44 AM #5
Real Name: Patrick
Real Name: Patrick
Headlights
Foglights
Tan steering wheel
Overhead console
Rear hatch
Ecu
Engine harness
Other lights
I don't think the climate unit/controls will be the same. SR5 has manual controls and Limited has digital controls.
Old 10-01-2021, 09:38 AM #6
garn79's Avatar
Real Name: Jeff
garn79's Avatar
Real Name: Jeff
thanks for input gents, its appreciated! @Team Jake @Bad Luck @UnderFire .
not looking so much so resell anything just looking for spare stuff for my own rig..
would ECM be compatible?
Old 10-01-2021, 12:45 PM #7
Team_Jake's Avatar
Team_Jake's Avatar
Not sure, because it's a different year, the part numbers will be different, but the connector pin plugs are exactly the same between the two, so they might be compatible. I do know though that different trim levels all shared the same ECU, meaning there's no ECU specific to the Limited or SR5.
Old 10-01-2021, 01:17 PM #8
phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of
Not really - it will have the immobilizer system and won't start your truck.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-01-2021, 04:57 PM #9
Team_Jake's Avatar
Team_Jake's Avatar
I think you and I may have debated this in the past, but I can't remember the conclusion.
I believe the immobilizer and ECU are essentially completely separate, all the ECU does is store codes the immobilizer system checks and makes sure it matches your keys, if that match is incorrect, the immobilizer keeps the engine from starting, not the ECU. I don't believe the ECU cares if the vehicle has an immobilizer or not. The reason I believe this is because the ECUs between immobilizer and non-immobilizer vehicles are the exact same part number, there's no immobilizer specific ECU.
Am I wrong? Or would an ECU from a vehicle with an immobilizer not work (or need to be reset/flashed) if switched to a vehicle without an immobilizer?
Old 10-01-2021, 08:07 PM #10
I have an ECU in my garage from a '99 4x4 Limited that won't start my SR5 truck... so yeah.
Immobilizer wiring goes to the ECU, it has the key amp, the output to the security light, etc. inside the ECU.
The OEM security system is a separate thing and is part of the body ECU.
Old 10-01-2021, 09:24 PM #11
3bears 3bears is offline
Real Name: 3 Bears
3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light
Real Name: 3 Bears
if it has a "sport hood" grab it
2000 SR-5 Highlander. 4:30's, factory locker green bought 6/21
2000 SR-5 V6 Auto . lifted, e locker, other cool stuff, totaled 10/20
4x4 , auto , elocker , grab , parts
tacoma bilsteins compatable? SuperSavage 4th Gen T4Rs 3 03-02-2015 03:33 AM
FS:99SR5, 5sp, Supercharged, Va 8k jesco For Sale: Vehicles 9 05-25-2013 05:58 PM
Wiring diffrences between 99SR5 and 2000 limited moonroof switch? hawkcharmer 3rd gen T4Rs 0 10-15-2012 06:24 PM
Are these bilsteins compatable with an 02?? Idahosr5 3rd gen T4Rs 1 07-14-2011 09:50 PM
Is Eclipse AVN 5435 Nav disc Compatable with AVN 2454? pdiddy Engines / Suspension / Wheels / Tires / Audio / Accessories 2 06-24-2006 11:59 AM
