Old 10-03-2021, 02:47 PM #1
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Engine Sputtering and Very low Idle on 3.4L when Shifting to R/D
When I pop my truck in either R or D the idle gets very low and it starts to sputter/shake. I also noticed that if I leave my truck to idle for more than 5 minutes the check engine light turns on which is the bad o2 sensor after the cat but I don't think that's my problem. When driving, it does goes away but I want to know as to why my truck is giving me a very low idle when shifting to R and D. This is intermittent - when I tried to diagnose it, it wasn't doing it. Any tips to resolve this?
2000 4Runner Limited 4x4 V6
Old 10-03-2021, 03:05 PM #2
I'm gonna be cleaning the troubled IAC Valve right now and see if that fixes it.
Old 10-03-2021, 04:55 PM #3
4runnerfiend's Avatar
4runnerfiend 4runnerfiend is offline
4runnerfiend has a spectacular aura about 4runnerfiend has a spectacular aura about
What code are you getting for the check engine light?
Sounds like a vacuum lead possibly. Do a visual inspection for any cracked old hoses or loose or unattached lines.
IG: @4runnerfiend- 1999 SR5: TRD Supercharger, ELocker, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, DuroBumps, RidgeGrapplers, Doug Thorley Headers, yellow top, XRC 12k, ARB single compressor.
4runnerfiend is offline   Reply With QuoteReply With Quote
Old 10-03-2021, 05:18 PM #4
I'm not sure on the code # but I know it was the o2 sensor code behind the cat. Hoses seem to be decent enough but I did find the intake hose near the throttle body cracked so I will replace it.
The IAC Valve was hella gunked up so cleaning it with TB Cleaner made it look and perform better and while I was there I also cleaned the TB itself. First inicial startup..... it ran normal but the idle drop was not present anymore so I hope it stays like that for good (the problem was intermittent).
engine , idle , low , shifting , truck
2006 4Runner V8 slight rough idle/sputtering paweliania 4th Gen T4Rs 14 03-26-2020 12:45 PM
Rough Idle and sputtering = stall Deceptiwave 3rd gen T4Rs 9 10-13-2019 11:21 AM
Rough Idle, Engine Sputtering, Engine Ticking, Flashing CEL Sotovo 3rd gen T4Rs 29 04-18-2016 10:35 PM
22RE sputtering @ idle & when off gas jechols Classic T4Rs 1 01-24-2008 12:32 AM
