Old 10-03-2021, 06:50 PM #1
pabst pabst is offline
pabst is on a distinguished road
Break cable extension kit question?
I finally got the Toyotech boss lift Installed by a shop. Notice that the brake bracket was ziptied. So I ordered the Toyotech brake proportioning valve extension kit. I'm confused On how to mount it The holes don't lineup with the differential holes And the hydraulic line It's tight It doesn't need to go up Does anyone have any Install pictures
pabst is offline   Reply With QuoteReply With Quote
Old 10-03-2021, 10:54 PM #2
here's a picture .hope this helps
Break cable extension kit question?-20211003_144225_remastered-jpg
Old 10-03-2021, 11:09 PM #3
another picture
here's another picture where the top bracket is to high
Break cable extension kit question?-20211003_144233-jpg
Old 10-04-2021, 10:04 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Do you have a link to the product you are trying to install? I don't understand what you are trying to do based on your pictures and description
Old 10-04-2021, 11:39 AM #5
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
The rigid brake line should be attached to the lower hole, not the upper one. The lower hole of the extension bracket for the e-brake cable attaches to the upper hole (where your rigid brake line is now attached). The e-brake cable loop then gets attached to the upper end of the extension bracket.
I made my own extension bracket, but you can see below how things are supposed to mount up:
Edited - I found the Toytec extension bracket (BPV-K - Brake Proportioning Valve/Brake Cable extension Kit), looks like it's installed the same way as I installed mine, although the two holes in the Toytec may (?) line up with both holes in the axle, in which case you can use both fasteners:
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 10:54 PM #6
thanks for the help
Thanks for the help Spiker Engineering. The picture definetley helped !! Yours looks super clean. Did you take it apart to paint the diff or paint it on your rig? what kind of paint did you Use? also did you do a pan hard bar drop bracket?
Old 10-05-2021, 12:47 PM #7
Just get a California 4Runner and clean up the underside... that's just what they look like out here.
Here's how I did mine:
Notice I also slightly offset the upper hole to the side and used both the lower holes to keep the bracket aligned. Haven't bothered to paint it since it is aluminum.
If you have longer than stock rear shocks, you'll also want to run a longer rear brake line - or maybe just bend the upper (frame side) bracket a bit to make sure the rubber line isn't stressed at full droop. If you look carefully in my pic, you can see the aftermarket longer line on there too.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
brake , extension , holes , kit , toyotech
Air pump question, before I break something funshot 5th gen T4Rs 10 10-08-2018 05:00 PM
Question: does the ras wear/break? cloh09 4th Gen T4Rs 3 01-05-2014 02:58 PM
What is this bolt? Transmission extension crossmember question bsouthard 3rd gen T4Rs 3 07-06-2012 09:56 AM
Question on towing and break-in period RyanE 5th gen T4Rs 5 04-17-2010 09:26 AM
Break question? SurferRob 4th Gen T4Rs 6 01-06-2009 04:58 PM
