Old 10-05-2021, 11:14 AM #1
4runn34's Avatar
4runn34 4runn34 is offline
Real Name: Justin
4runn34 is on a distinguished road
4runn34's Avatar
Real Name: Justin
Right front wheel locked up on me
Driving to work today I had the right front wheel lock up just as I was braking to pull into the parking lot. I did the Tundra Brake Upgrade a couple months ago so it seems odd the brake caliper would go bad after 2 months. Could it be something with the CV or something else? I'm planning on getting it towed after work and then taking the wheel off at home to see what's going on.
1999 Toyota 4Runner Limited
4runn34 is offline   Reply With QuoteReply With Quote
Old 10-05-2021, 11:36 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Most likely a bad front caliper. Could also be a collapsed brake hose.
Old 10-05-2021, 11:39 AM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Bad caliper, looks like you got a dud. Request a warranty replacement.
326WHP 347TQ
Old 10-05-2021, 12:07 PM #4
4runn34's Avatar
Real Name: Justin
4runn34's Avatar
Real Name: Justin
I went out at lunch and got underneath and found the top caliper bolt was missing. So I walked back about 200 yards and found it laying on the road. Torqueing to spec is not enough apparently. When I get home I'll put loctite on all of them. I couldn't imagine having that happen at highway speeds.
Old 10-05-2021, 01:20 PM #5
spartacus's Avatar
spartacus's Avatar
Torque is 90 ft lbs. Are you positive that you torqued it? I've never put thread locker on caliper bolts' just anti seize and have never had any issues.
Old 10-05-2021, 03:53 PM #6
Real Name: Patrick
Real Name: Patrick
I agree with Spartacus above. I've never put loctite on any brake job I've done and I've never had a problem or a customer comeback. It's also extremely unlikely that the caliper bolt would back out if it was torqued correctly.
brake , front , months , wheel , work
Help, rear driver side wheel locked up in nuetral popsmckracken 3rd gen T4Rs 3 01-19-2017 08:28 PM
Key won't turn in ignition, wheel is NOT locked JMichael23 3rd gen T4Rs 10 03-25-2015 01:33 AM
front brakes locked Southtwnr 3rd gen T4Rs 8 03-06-2015 03:44 PM
2008 4runner front wheel locked caalbu 4th Gen T4Rs 1 01-26-2014 05:34 PM
Locked both front and rear?? Duhockey 3rd gen T4Rs 9 03-10-2010 12:04 PM
