Old 10-05-2021, 02:12 PM #1
Timjtitus Timjtitus is offline
Timjtitus is on a distinguished road
Can I remove these bolts without taking apart transmission?
I’m swapping my r150f with a rebuilt transmission and I’m transferring parts and brackets to the new unit. Two of the brackets are secured with bolts that hold the transmission together in the middle. The parts that’s secured with the red liquid gasket material. Can I back these bolts out and put on the brackets without causing a leak?
I couldn’t get the picture to load up. Will try again. Thanks for the help.
Timjtitus is offline   Reply With QuoteReply With Quote
Old 10-05-2021, 03:55 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
You should be fine to remove the bolts in order to transfer the brackets over. I would recommend doing 1 bolt at a time just to be on the safe side.
Old 10-05-2021, 05:00 PM #3
Thanks
bolts , brackets , parts , secured , transmission
Best way to remove exhaust bolts? Robb235 3rd gen T4Rs 60 03-18-2021 04:20 AM
CV joint swap. Remove LBJ bolts? ShooterMcGavin 3rd gen T4Rs 20 10-13-2016 07:53 PM
How to remove roofrack bolts? jjdbike 5th gen T4Rs 15 04-26-2016 05:04 PM
which tool to remove connecting rod & head bolts? rockthepouch Classic T4Rs 5 01-15-2012 12:54 PM
How to remove U-joint bolts Mr.pughe Classic T4Rs 6 11-28-2010 11:57 PM
