Old 10-06-2021, 11:42 PM #1
TucsonMike TucsonMike is offline
TucsonMike is on a distinguished road
Slow coolant leak
Is there an acceptable amount of coolant loss a vehicle will have over time? I have never really monitored coolant loss until the last few years when I had a lower intake manifold leak. I got that leak repaired about 3k miles ago ( I think) but I notice I have lost about 1/2 cup of coolant over 2600 miles. Car runs fine temps are fine and no visible external leaks or smoke during start up. I will continue to monitor to get a baseline before I decide if I want to do anything.
I've owned my 4runner since 2003 and currently has 280k
I have a v6 with 5speed and radiator is somewhat new.
Seeking out any advice
Thanks
MikeM
TucsonMike is offline   Reply With QuoteReply With Quote
Old 10-07-2021, 12:20 AM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
It wouldn't hurt to do the gaskets as I suspect they're probably the culprit personally. When I did my intake manifold gaskets ALSO around 280k (as part of solving a different issue) I noticed the material around both coolant passages on both gaskets was heavily eaten away, as in if I had left it for another year I probably would've been leaking into one of my intake valves - they were all holding on by a hair. Given both the age and mileage our vehicles are approaching I wouldn't put it past things if you have the same issue. And considering you can buy the gaskets online fairly cheap and it's not exactly a complex job (just tedious, especially by yourself) I would give it a whirl and see if it changes anything. I went with felpro instead of Denso as they were much cheaper and have absolutely nothing bad to say
Worst case scenario it was a few bills and an afternoon down the drain but at least you can rule it out at that point
Old 10-07-2021, 12:52 AM #3
Thanks for reply but I have already replaced the lower intake manifold gaskets. I should add the bypass and valley were dry. Water pump was dry and sparks plugs looked fine.
Thanks
MikeM
Old 10-07-2021, 11:20 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Thanks
MikeM
How are you determining that the coolant loss?
Old 10-07-2021, 11:34 AM #5
spartacus's Avatar
spartacus's Avatar
Wouldnt hurt to test the cap for the correct psi. I believe its rated 15.6 psi. You can rent one from loan a tool program at the big block auto stores.
Old 10-07-2021, 12:28 PM #6
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
you say you did the lower intake gaskets 3000 miles ago and since have lost 1/2 cup of coolant.....was it all of a sudden ? did you just now noitice and have not really paid attention to it since the intake manifold gaskets ? Maybe it just needed to burp an air pocket.
I had a 2001 for a brief time, it would loose coolant...part of its issue is previous owner had installed wrong radiator cap
Old 10-07-2021, 01:27 PM #7
I have been checking coolant level in the morning and right after I had gaskets replaced I was checking it daily. I'd say the first couple thousand miles I didn't see a drop in coolant and didn't check it for awhile and lately notice it was about 3/8 below the full line when engine is cold. I'll continue to monitor it and see if it drops any further over time.
I might pressure test it as well
Thanks
MikeM
Old 10-07-2021, 03:44 PM #8
Been there, done that on multiple Toyotas. A new OEM cap fixed it.
Not saying that is the issue in this case, but also worth checking.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-07-2021, 03:57 PM #9
I did by a spare cap and can try it to see. My current cap I replaced over 100k miles ago so I supposed it could be due. Doesn't hurt to try since I already have one
Thanks
MikeM
Old 10-08-2021, 01:56 PM #10
JustTroItIn's Avatar
JustTroItIn JustTroItIn is offline
JustTroItIn is on a distinguished road
You can get some UV dye and glasses. If the leak is external this should help you locate it.
2000 Limited w/ rear locker
-Dobinsons IMS, JBA UCA, Whiteline Bushings
2000 SR5 4WD Auto w/ J Shift
-Stock Beater
JustTroItIn is offline   Reply With QuoteReply With Quote
coolant , fine , leak , loss , miles
2007 v8 - slow coolant leak behind water pump advice Jcmeadows82 4th Gen T4Rs 6 04-28-2019 12:47 AM
Very slow coolant leak 4Runner4TW 3rd gen T4Rs 9 02-02-2016 08:27 AM
Coolant leak solution, pepper, eggs or liquid aluminum stop leak? BUGSEY General Discussions 1 01-30-2014 01:32 PM
Coolant Leak- Drivers side coolant manifold? Shibby! 3rd gen T4Rs 19 12-28-2012 09:37 PM
Coolant leak, whining noise, vacuum leak, alternator, starter, battery issues Max O 3rd gen T4Rs 4 12-03-2009 10:31 AM
