Old 10-07-2021, 08:30 PM #1
pink_sleeve pink_sleeve is offline
pink_sleeve is on a distinguished road
OBD2 port linking error
2001 SR5. I am getting a linking error at the OBD2 port. No blown fuses. Pin 16 has power. Pin 4 to 16 shows around 12 volts. Pin 5 to 16 shows less then 1 volt. And the other pins 15 and 7 I’m not sure how to check for continuity. I’m not even sure what pin 5 should read. I can’t seem to find a chart showing exactly what each of the port pins are. Any help would be appreciated.
pink_sleeve is offline   Reply With QuoteReply With Quote
Old 10-09-2021, 02:53 PM #2
habanero's Avatar
habanero habanero is offline
Real Name: Throws like a girl
habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light
habanero's Avatar
Credit to MTL 4runner when it was provided to me in '06 when I had a similar issue....
Pin 5 should be a ground, as should pin 4...
Pin #, Description
4 - Chassis Ground
5 - Data Ground
7 - Data
15 - Data (this pin is optional and may not be present)
16 - Power
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R View Post
I know this is a weird ass question but do you shave your legs or something?
habanero is offline   Reply With QuoteReply With Quote
Old 10-10-2021, 12:26 AM #3
Shouldn’t the data ground register 12v? Mine registers like 1.
Old 10-10-2021, 09:46 AM #4
habanero's Avatar
habanero's Avatar
Keeping in mind my electrical knowledge is weak...
Pin 5 is a ground, check for resistance with a known good ground to confirm your bad ground.
That's where my issue happened to be, so I created a ground at the connector rather than hunt down the problem child.
i’m , obd2 , pin , pins , port
Linking flood/spot lights to door chime? Dom8706 3rd gen T4Rs 8 04-13-2020 02:25 PM
Obd2 mmt 4th Gen T4Rs 1 02-22-2017 09:50 AM
Obd2 mmt Engines / Suspension / Wheels / Tires / Audio / Accessories 0 02-21-2017 07:10 PM
OBD2 port Pin16 is 11.3volts. what's the right voltage? radlynx 4th Gen T4Rs 2 02-02-2016 03:54 PM
Is your bluetooth not linking up? snowbizx 4th Gen T4Rs 4 12-18-2008 12:54 AM
