Old 10-08-2021, 04:31 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Changed power steering fluid, are bubbles normal?
I just tried changing my power steering fluid. I used the Fix It Angel video where you fit a hose into a bottle of ATF so that you can drain it directly into the reservoir as you turn the wheels.
I just reconnected the hose, and filled it with fluid. When I tried turning the car on, the PS made a terrible sound. I opened the reservoir and the fluid was bubbling like a soda. Is this normal and will these bubbles go away on their own?
Also I got someone to turn the wheel while I drained the bottle. They thought I was going to give them a signal when to turn the wheel, and by the time I figured this out the gallon of transmission fluid was too drained to finish the job. When I go back later to do this job again, do I have to run the engine? Can I get by with switching the ignition into the ACC position and turning the wheels lock to lock manually?
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 10-08-2021, 05:59 PM #2
It'll take a bit for all the bubbles to go away. Make sure you keep the level up in the reservoir. You can help by turning the wheels lock to lock with the engine running and keep topping up the level until it is clear.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-09-2021, 12:16 AM #3
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
I have had the ATF foam up (presumably from air gaps/bubbles in the system) after exchanging the ATF. As long as you keep adding ATF to keep the system filled to the correct level, the foamy bubbles will gradually (like over 5 minutes) go away as the engine runs.
BTW, if all you need to do is change out the ATF, you can easily pump it all out without starting the engine, by having the front wheels off the ground and repeatedly turning the steering wheel lock to lock. Because the pump isn't turning, you don't get foam or noise from/damage to the pump.
pluton is offline   Reply With QuoteReply With Quote
drained , fluid , power , turn , wheels
Power steering fluid level low. Do I use ATF or power steering fluid? 4flyer 3rd gen T4Rs 63 02-24-2020 05:07 AM
Power Steering - cap says Dexron ATF, dealer tech says power steering fluid acolsen Maintenance/Detailing 7 02-24-2017 03:00 PM
power steering fluid catrains 5th gen T4Rs 7 12-17-2016 05:09 PM
Is it normal for power steering to squeal at full lock? 5VZFE 3rd gen T4Rs 7 02-04-2015 01:22 AM
Power steering fluid dmanla Maintenance/Detailing 2 08-22-2008 05:39 AM
