Old 10-18-2021, 02:20 PM #16
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
You definitely used to have a factory rack. If they left the holes open it would leak into the interior.
Old 10-18-2021, 03:32 PM #17
tpelletier tpelletier is offline
tpelletier is on a distinguished road
Originally Posted by Cree View Post
Factory rivnuts filled with RTV. Someone hated you.
This is gonna suck.
ill have to drill into the rubber and pour acetone in I guess ?
tpelletier is offline   Reply With QuoteReply With Quote
Old 10-18-2021, 03:52 PM #18
Real Name: Patrick
Real Name: Patrick
Originally Posted by tpelletier View Post
This is gonna suck.
Be careful you don't damage the headliner by dripping acetone on it. You might try scraping the top of the rivnut with a razor blade and then taking a pocket screwdriver to try to unscrew the rtv from the threads. You might get lucky
Old 10-18-2021, 04:04 PM #19
Cree's Avatar
Cree Cree is offline
Cree will become famous soon enough Cree will become famous soon enough
Cree's Avatar
I would use a sharp exacto knife, cut out as much of the sealant inside the threads as I could and find a bolt to do the rest of the work.
Or buy another truck. Might be easier.
00 Limited - Stuff!
18 Audi A6 3.0T - APR Tuned, RS6 Interior
19 Audi A6 3.0T
Cree is offline   Reply With QuoteReply With Quote
Old 10-18-2021, 05:57 PM #20
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
My plan would be to cut/pick as much out as possible, then use a tap to finish the job/clean up the threads.
Not interested in buying a tap? Cut a couple relief grooves in the right sized bolt, you just want a"sharp" edge to scrape the threads and someplace for the RTV to go once loose. In and out just a turn at a time, pick/vacuum out whatever comes loose each time.
Just labor intensive, not hard.
Brian. is offline   Reply With QuoteReply With Quote
Old 10-19-2021, 09:02 AM #21
Thanks for the ideas yall, ill give an update after I give it a go this weekend.
Old 10-19-2021, 01:14 PM #22
It should be M6x1.0 threads...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-21-2021, 10:43 PM #23
ToyotaBrah's Avatar
ToyotaBrah ToyotaBrah is offline
ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about
ToyotaBrah's Avatar
I have a hunch the previous owner had an aftermarket rack on it. I see 6 holes on one side, and I know the factory rack is held on by only 5 torx bit screws per side. That last hole (one closest to front of truck) looks a smidge bigger than the factory rack thread holes. I'm interested in what you uncover. Keep us updated.
ToyotaBrah is offline   Reply With QuoteReply With Quote
Old 11-02-2021, 03:30 PM #24
Turns out taking out silicone was super easy, took about 10 seconds per thread with a box cutter..
the install went smoothly and got to use the basket on a 400mile trip to north florida where we packed the crap out of the car 1000lbs+
Operatoin roof rack/basket successful.
thanks yall.
2002 Roof side rails-whatsapp-image-2021-11-02-3-10-04-pm-1-jpg  2002 Roof side rails-whatsapp-image-2021-11-02-3-14-00-pm-jpg  2002 Roof side rails-whatsapp-image-2021-11-02-3-10-04-pm-jpg
$200 , install , rails , roof , side
Roof rails side stress skt4271 5th gen T4Rs 4 11-30-2019 10:48 AM
FS - 2015 OEM Roof Side Rails - Dallas, TX - $250OBO Boba_Fox2015 For Sale: T4R Items 0 03-10-2019 12:14 PM
Roof Box outside the side rails BurghRunner General Discussions 2 08-20-2017 07:27 AM
WTB 4th Gen roof rack side rails. bolantej For Sale: T4R Items 2 06-23-2017 12:28 PM
96-2002 3rd gen roof rack with rails doylee4693 Classifieds - buy & sell (no commercial ads please) 3 03-19-2011 10:30 AM
