Originally Posted by TucsonMike
R U sure it's not normal? My v6 5speed high idles when weather is cold and kicks down to normal once warm. I noticed today my idle was around 1500 on startup and temp in Tucson is around 70. Unless ur vehicle idle starts acting erratic I wouldn't worry about it.
texadelphia
Yeah, I idle at about 1200-1500 on a cold start until I warm up a bit and settle down to about 750, especially if it's not very hot outside. I should clarify it's a smooth 1200-1500, it's not rough. If it's smooth, and consistent, then maybe it's normal? Or at least OK? But that climb to 2100 sounds strange. I like
Bad Luck
's IAC idea. Make sure to position the IAC cavities upside down when spraying the TB cleaner. This is to allow the gunk to drain out instead of collecting/pooling inside there.
