Old 10-11-2021, 11:09 AM #1
AJPuleo23's Avatar
AJPuleo23 AJPuleo23 is offline
AJPuleo23 is on a distinguished road
AJPuleo23's Avatar
Check out my new clock
An ode to my 272k mile cracked flexplate. Now, a new garage hanger.
Check out my new clock-flexplate2-jpg  Check out my new clock-flexplate3-jpg  Check out my new clock-flexplate1-jpg
'01 SR5 - 270k - 3" Toytec Ultimate Coils - SPC UCA's - MotegiMR150 17x8.5 + Yoko Geo 295/70/R17
AJPuleo23 is offline   Reply With QuoteReply With Quote
Old 10-11-2021, 12:37 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 is a jewel in the rough jgue467 is a jewel in the rough jgue467 is a jewel in the rough
jgue467's Avatar
Nicely done! I like to repurpose stuff whenever I can too.
Could be a new business idea....
2001 Limited 4WD - 333+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
Old 10-11-2021, 12:39 PM #3
Dannybetz Dannybetz is offline
Dannybetz is on a distinguished road
I love the steampunk feel to it
Dannybetz is offline   Reply With QuoteReply With Quote
Old 10-11-2021, 01:41 PM #4
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light
Devbot's Avatar
Real Name: Devan
Love how simple it is, very minimalist
Y2K Highlander Millennium Silver 3.4L auto @ 295k and climbing
Tundra TRD Lift in Front / LC Lift in Rear / JBA UCAs / CVJ 9168R Axles / Diff Drop / PCK / Extended Bump Stops; Brake Lines; Sway Bar Links; Rear Diff Breather / True North Fab. Hybrid Bumper / Smittybilt XRC Gen 3 Comp. / Northstar 880CCA AGM / Drivelines NW Rear Shaft / Lil Skip Gas Skid / BudBuilt Front Skid
Old 10-11-2021, 04:22 PM #5
Pyral's Avatar
Pyral Pyral is online now
Real Name: N/A
Pyral is on a distinguished road
Pyral's Avatar
Real Name: N/A
flexplate works better as a clock than most of the digital clocks in our 4runners
1998 4runner 2.7 manual
Pyral is online now   Reply With QuoteReply With Quote
Old 10-11-2021, 05:22 PM #6
Bad Luck Bad Luck is online now
Real Name: Patrick
Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold
Real Name: Patrick
How loud was that before replacement?
2000 Limited V6 Auto E-Locker
Bad Luck is online now   Reply With QuoteReply With Quote
Old 10-13-2021, 11:49 AM #7
AJPuleo23's Avatar
AJPuleo23's Avatar
LOL my OG digi clock has been black for going on 12+ years now...
Old 10-13-2021, 11:52 AM #8
AJPuleo23's Avatar
AJPuleo23's Avatar
As someone who has self-diagnosed OCD when it comes to my vehicles, loud enough to drive you mad.
If you don't mind a consistent fairly loud tapping noise at idle, mixed with the anxiety of knowing that it can shear off at any point in time and take whatver is in the bell housing with it - then I suppose you can drive it without worry... LOL.
Old 10-13-2021, 11:56 AM #9
Real Name: Patrick
Real Name: Patrick
Thanks for the reply. I've replaced a few gm ones that sounded like absolute death and one or two that barely made a noise so I was curious about yours
Old 10-13-2021, 12:26 PM #10
AJPuleo23's Avatar
AJPuleo23's Avatar
yeah, in the last few months I went through and did the TB job and replaced every damn drive pulley/belt I could think of. Just to further confirm my suspicions of it being the flexplate. Once I still heard the noise after that, I knew there was not much else that could be causing it from the research I had done.
I wish I had a video/recording of it for any kind of reference. But it was loud enough at a stop to be heard with the driver window down over the sound of the motor, or through the cab with the windows up and stereo off.
Old 10-13-2021, 10:05 PM #11
NegroTundra NegroTundra is offline
NegroTundra is on a distinguished road
Best clockmaker on mars
98 T4R 3.4L 5speed Elocker 4x4
06 Honda Accord 2.4L
16 Dodge Ram 2500 6.7L Cummins fully deleted
NegroTundra is offline   Reply With QuoteReply With Quote
Old 10-14-2021, 02:32 PM #12
cblock406's Avatar
cblock406 cblock406 is offline
Real Name: Christian
cblock406 has a spectacular aura about cblock406 has a spectacular aura about cblock406 has a spectacular aura about
cblock406's Avatar
I thought this was a fix/mod/solution for the crappy digital dash clocks that inevitably fail, ha. This is much cooler!
Build Thread: http://www.toyota-4runner.org/3rd-ge...ce-thread.html
@projects_always
cblock406 is offline   Reply With QuoteReply With Quote
272k , check , clock , mile , ode
No need for temp check mode: Eas(ier) ways to check WS transmission fluid level JB. 4th Gen T4Rs 36 11-02-2019 11:48 AM
Check Engine Light, VSC OFF And Check VSC Lights just came on??? the_josh Maintenance/Detailing 5 07-15-2019 01:25 PM
Clock is dead and don't really need a clock. What can go in place? blairracd 3rd gen T4Rs 32 07-09-2018 09:52 AM
24-hr clock dron 5th gen T4Rs 0 08-06-2010 11:24 PM
Clock clinte234 Maintenance/Detailing 3 08-29-2007 08:09 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
