Old 10-14-2021, 04:51 PM #16
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by jman11788 View Post
Sure did. It at lined up. I managed to get it on there but it seems too tight
Are you referring to the cable sheathing (the outer part) or the cable itself (inner part)? Got any pics of it installed now?
Old 10-14-2021, 07:44 PM #17
jman11788's Avatar
jman11788 jman11788 is offline
jman11788 is on a distinguished road
jman11788's Avatar
For some reason my phone won’t upload the pic. I’ll upload it tomorrow at work.
So far it’s shifting butter smooth now. Hopefully it doesn’t come back we will see. So right now successful repair 👍🏼
2000 Limited 4wd Supercharged with E-Locker
jman11788 is offline   Reply With QuoteReply With Quote
Old 10-16-2021, 03:57 PM #18
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
In the off-chance you have a throttle body spacer take it off as that's the only thing that will make it too tight. Make sure the lock nuts are out as far as they possible can to give you an extra 1/2 in from the threads. Every millimeter helps, quite literally!
326WHP 347TQ
Old 10-18-2021, 05:04 PM #19
jman11788's Avatar
jman11788's Avatar
No throttle spacer. That's exactly what I did. Maxed out the threads then put it on the bracket. Was a little worried when I started adjusting it would break the cable loose like last time but still intact. Shifting real good now
Why does the fsm say to remove valve body? I didn't see a reason why you would.
1st , 2nd , cable , grooves , stay
Transmission kickdown cable question T4Rscott 3rd gen T4Rs 38 05-16-2023 10:30 PM
2000 4runner a340f kickdown cable (tv cable) broken DPR64 3rd gen T4Rs 3 09-07-2021 02:28 PM
throttle valve cable/transmission kickdown cable stuck roll4life 3rd gen T4Rs 4 08-16-2016 02:03 PM
Accelerator and Transmission kickdown Cable Bracket P/N ? JARO 3rd gen T4Rs 1 07-15-2016 11:43 AM
tranny kickdown cable SAYWHAT 3rd gen T4Rs 12 02-23-2015 10:59 PM
