Old 10-14-2021, 01:13 AM #1
HiluxChuck's Avatar
HiluxChuck HiluxChuck is offline
HiluxChuck is on a distinguished road
HiluxChuck's Avatar
Fan mount stud came out
Hi
I'm midway through a timing belt change and when I removed the fan mount thing that is held on with 3 studs, one of the studs came out completely instead of the nut.
How do I get the stud back in and tightened down? Or does the nut hold it in place?
Hopefully someone knows what I am talking about 😋
It's the 5vz engine
Thanks
HiluxChuck is offline   Reply With QuoteReply With Quote
Old 10-14-2021, 05:43 AM #2
NEKExplorer's Avatar
NEKExplorer NEKExplorer is offline
NEKExplorer is on a distinguished road
Save the stud, if you have a bench vise try and get the nut off the stud. There is a trick you can do with two nuts on the stud so you can use a wrench to get the stud back in tightly. I put a little red loctite on the threads on mine before I did this. You can find videos of the two nut trick on studs on youtube.
"If the American people ever allow private banks to control the issue of their currency, first by inflation, then by deflation, the banks and corporations that will grow up around them will deprive the people of all property until their children wake up homeless on the continent their Fathers conquered...I believe that banking institutions are more dangerous to our liberties than standing armies... The issuing power should be taken from the banks and restored to the people, to whom it properly belongs."
NEKExplorer is offline   Reply With QuoteReply With Quote
Old 10-14-2021, 07:47 AM #3
HiluxChuck's Avatar
HiluxChuck's Avatar
Thanks NekExplorer
The stud is fine, the nut came off easily. Do the studs really have to be put in tight with red Loctite or will the torque of the nut stretch the stud and keep it in place?
The reason I ask is because I put it all back together thinking a hand tight stud will be fine if the nut is on tight. Should I take all the belts off and redo the stud or will it hold as is?
Old 10-14-2021, 08:45 AM #4
I think it will probably be fine. If it comes out again next timing belt change maybe try the loctite.
fan , mount , nut , stud , studs
part# for rear wheel stud / Matrix AWD wheel stud compatibility with OEM wheels jdm-v35 5th gen T4Rs 3 06-29-2021 05:52 PM
Strut Mount Stud Replacement slimjj 4th Gen T4Rs 1 11-07-2016 05:07 PM
Extended upper strut mount stud dimensions blackoutt 4th Gen T4Rs 1 09-28-2015 08:24 AM
FS: Firestik II antenna with spring, stud mount, and hood mount - $35 Orange County Jeddy For Sale: Non-T4R Items 0 07-02-2014 05:57 PM
WTB: 3rd gen extended stud for strut mount t4r4life Want to Buy/Trade 2 09-01-2010 04:16 PM
