Old 10-17-2021, 04:38 PM #1
k2damfc k2damfc is offline
k2damfc is on a distinguished road
Fuel pump jumper
woke up this morning to my fuel tank leaking like a siv. its coming from one of the pinch flaps on the tank itself, been trying to figure out how to jumper out the fuel pump to get it to pump the gas out, since i filled it yesterday, before i drop it. Everything ive searched for says "Jumper the B+ and the Fp in the diagnosis block under the hood" problem i'm having is there is no terminal for the Fp, well its labeled as such but there isnt a spade electrical connection inside of the space. under the whole thing there are only 5 actual connection points.
Currently have a catch pan under the tank and the fuel filter line disconnected and dropped into a 5 gallon tank and need to figure out how to fill up the 5 gallon tank 3 times to get it emptied. Pump was a POS aftermarket one and seems to be causing me problems anyway, don't care if i burn it up since im dropping the tank and getting a new one, i will replace the pump with a Denso.
Please help me out here sooner then later, i'm looking up stuff on the internet instead of draining the gas as it leaks into my dirt driveway.
Forgot to mention, 99 4runner Limited
k2damfc is offline   Reply With QuoteReply With Quote
Old 10-17-2021, 07:01 PM #2
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
You should be able to apply power directly to the pump connector under the seat, try a 9v battery and some alligator clips
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 10-18-2021, 09:55 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Be careful you don't burn the pump up once the tank level starts getting lower
Old 10-18-2021, 07:20 PM #4
I’d imagine the pump is getting replaced while the tank is out, new denso pump isn’t very expensive on rock auto
Old 10-19-2021, 09:56 AM #5
Real Name: Patrick
Real Name: Patrick
He said the leak was "coming from one of the pinch flaps on the tank itself." I have no idea what or where he's talking about so I have no idea if the pump is getting replaced or not.
fuel , gas , jumper , pump , tank
Replace Fuel Pump - Drop Fuel Tank? Rock_Rat 3rd gen T4Rs 11 12-17-2023 05:33 PM
No Fuel? Bad Fuel Pump? Bad Fuel? Aliens? Gremlins? 007Tacoma 5th gen T4Rs 12 05-04-2018 09:08 AM
Repeated fuel filter clog, failing fuel pump, or ? hour 3rd gen T4Rs 74 10-09-2016 12:58 PM
Fuel pump test jumper - 94 Camaro1976 Classic T4Rs 4 06-15-2011 04:17 PM
Fuel pump whining. Clogged fuel filter or bad pump? Shawn5800 3rd gen T4Rs 3 04-18-2011 02:08 AM
