Old 10-22-2021, 03:32 PM #16
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by mtbtim View Post
All the precautions you mentioned we covered in the video. We actually dropped a shim into one the head black holes and I was able to fish if out with my magnet tool. After that we plugged up all the areas a shim or whatever else could drop into. No way would I pull an intake cam to replace a valve shim because that's way too much work. Pulling the exhaust cam is very easy and worth it if you have lots of valves out of spec like we did.
The last valve job I did I pulled the intake cams, twice. Was installing performance cams. They went back in the shed after the old engine blew though.
The only time pulling the intake cams is even close to being economical for time is if you are also doing the timing belt, in which that particular case I was. It made swapping shims very easy.
326WHP 347TQ
Old 10-23-2021, 09:51 AM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Great video as I haven't had to adjust valves on these engines yet. Good grief in the amount of time and patience needed to get the project done.
Sure alot more complicated then the 22R engine when I you needed was the filler gauge screw driver and wrench.
It was great to see his engine compression come back though. That's rewarding and by doing so gained more hp and torque back..
3.4l , 5vz-fe , experience , job , valve
V8 valve clearance inspection 064runnerv8 4th Gen T4Rs 2 09-15-2019 08:30 AM
Engine Valve Clearance Inspection - 2003 4.7l V8 - Worthwhile??? AndroT100 4th Gen T4Rs 17 05-26-2011 01:47 AM
Valve adjustment pacesos 4th Gen T4Rs 1 02-14-2009 11:49 AM
Valve adjustment? rdgt4r 3rd gen T4Rs 16 01-11-2009 06:11 PM
valve adjustment?!?!? crappled Classic T4Rs 3 06-09-2005 05:24 PM
