Old 10-21-2021, 04:20 PM #1
AirOlson AirOlson is offline
Real Name: Jordan
AirOlson is on a distinguished road
Real Name: Jordan
Dual Batteries
Does anyone know why my Hilux Surf would come with a dual battery setup from factory? There is nothing extra in terms of lighting or aux outlets, compared to Canadian or USA 3rd Gens.
Do diesels require more power to start?
2001 Hilux Surf SSR-X 1KD-FTV
1998 3.4 Sr5 4WD - SOLD
AirOlson is offline   Reply With QuoteReply With Quote
Old 10-21-2021, 04:34 PM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Abso-friggin-lutly. Not only does it take more amp to turn over an engine with twice the compression as a gas engine, but in cooler weather you're Also burning glow-plugs (before engine start) which is Another huge load.
Dual batteries aren't necessary for diesel, my VW diesel only had 1 battery, but I think you'll find it's more normal for either 2 batteries or 1 Huge one as you get into larger displacement engines. My VW only had a 1.9l engine. Even there, a brand new battery would need to be replaced by either the 4th or 5th winter (depending on when I installed it), whereas the batteries in my gas vehicles routinely go more than 8 with some hitting 10+ years.
Brian. is offline   Reply With QuoteReply With Quote
Old 10-21-2021, 04:49 PM #3
Can you post pictures of how the OEM dual battery setup is done?
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-21-2021, 06:37 PM #4
It might be like my cummins where there was a battery at each headlight. I had two Group 27’s. Newer ones use dual 65’s.
Old 10-21-2021, 08:26 PM #5
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Huh, that's a really good question. I've seen maybe 2 or 3 diesel Surf owners on here so one of them would have to know, on the off chance they see this. Can't remember any of their usernames to tag them right now. I would definitely imagine they do but I've never once heard mention of it - but then again, there's not much talk on the diesel models anyways since we never got them here in the states and the overwhelming majority of the userbase here is American
Diesels absolutely require more power and more often than not have dual batts from the factory; as Brian said you can get away with one sometimes, but that's almost always with tiny TDI engines. I believe my buddies cummins actually has 3 batteries, if I remember correctly
Old 10-21-2021, 09:18 PM #6
Real Name: Jordan
Real Name: Jordan
Here ya go!
Dual Batteries-45-1-jpg
Old 10-21-2021, 10:54 PM #7
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Here ya go!
Is it just me or is that a cleaner and more organized bay than the 5VZ
Old 10-22-2021, 11:03 AM #8
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
No cruise control, no evap charcoal box, no rear heat, no spark plug wires, and an intercooler hiding much of the hoses and wires on the motor. Plus an abnormally clean white firewall...
JohnMc is offline   Reply With QuoteReply With Quote
Old 10-22-2021, 12:46 PM #9
blarchitect blarchitect is offline
blarchitect is on a distinguished road
The dual battery was an option on Japanese Surfs. It was called the winter package as gets cold in the north, where snow and ice dominate in the winter.
blarchitect is offline   Reply With QuoteReply With Quote
Old 10-22-2021, 04:50 PM #10
AJPuleo23's Avatar
AJPuleo23 AJPuleo23 is offline
AJPuleo23 will become famous soon enough
AJPuleo23's Avatar
Man, that thing is cool looking.
2001 SR5 | 275K+ | 3" Toytec Ultimate Coils | SPC UCA's | MotegiMR150 17x8.5 + Yoko Geo 295/70/R17 | 4Xi full drivetrain skids | OCD sway bar links F&R | Powerstop TBU | Opt OR Upper & Lower rear arms | MF Overland Exhaust | Retrofit LEDs | Vivid Lumen Fogs | Full Prinsu Rack | Front bumper retrofit/fat lip delete
1983 Pickup SR5 | 93K | LCE Street Headers | 31x10.5 BFG K02's, Full Desmog and Otherwise Original
1981 Pickup SR5 longbed | 142K |
AJPuleo23 is offline   Reply With QuoteReply With Quote
Old 10-22-2021, 07:47 PM #11
busmup808's Avatar
busmup808 busmup808 is offline
busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough
busmup808's Avatar
Dual Batteries
The kz diesel motors air box routes to the L side because of the OEM batteries on both corners of the engine bay. I believe the starter battery is on the R and the other is on the L. I was going to swap this motor in my truck, but decided not to in the last minute very capable turbo/diesel. My 2nd reason for not doing the swap is because I already have a R side snorkel. Dual BatteriesDual Batteries
Busmup808 all day, all night!
busmup808 is offline   Reply With QuoteReply With Quote
aux , canadian , dual , lighting , outlets
For those with dual batteries BMeister 4th Gen T4Rs 21 07-18-2018 02:05 PM
Dual Batteries DougieFresh Classic T4Rs 4 02-27-2011 12:37 AM
dual batteries? SCRunner Engines / Suspension / Wheels / Tires / Audio / Accessories 3 04-02-2009 02:42 PM
Dual Batteries in a SR5 V6 teotwaki Engines / Suspension / Wheels / Tires / Audio / Accessories 3 03-22-2007 12:12 AM
