Old 10-24-2021, 07:41 PM #1
5VZ-FE's Avatar
5VZ-FE 5VZ-FE is offline
5VZ-FE will become famous soon enough 5VZ-FE will become famous soon enough
5VZ-FE's Avatar
Brakes gone after a puddle
It’s been torrentially rainy here in Norcal and I’ve had to drive through some pretty deep puddles to get around.
A few times when I go through deeper ones I’ve been hearing a belt squeak, which was weird.
I went through another pretty deep one (the Prius in front of me had water above the doors) and heard the belt squeak, then when I got out I had almost no braking power. The pedal went almost all the way to the floor before I felt any resistance, and it barely stopped. I parked and pumped the pedal and it felt a little better so I drove home, mostly engine braking.
Brake fluid looks good and I couldn’t see anything wrong at any of the wheels…
Master cylinder?
‘98 T100 SR5 4X4 5spd (sold)
‘99 4Runner SR5 4x4 5spd E-Locker Unicorn
5VZ-FE is offline   Reply With QuoteReply With Quote
Old 10-25-2021, 11:08 AM #2
spartacus's Avatar
spartacus's Avatar
AC compressor pulleys tend to squeal when cold or wet. The brake booster check valve might be going out. when you blow through it it should only work one way.
Old 10-25-2021, 01:30 PM #3
That really shouldn’t happen just hitting a big puddle.
Do you have any rusty brake lines?
Old 10-25-2021, 11:04 PM #4
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
any loose brake line connections ? Water enter the system somewhere and f the fluid up?
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 10-26-2021, 01:54 AM #5
5VZ-FE's Avatar
5VZ-FE's Avatar
So they feel a lot better today (it’s dry now) in terms of stopping power compared to yesterday. However, now they are lurching. As I was driving down a long hill and I was slowing down towards a light it felt almost like the brakes were pulsing, a little like how ABS slows and then it releases a little and then slows again. But this definitely isn’t abs. Also when I was parking on the street I think one of the front brakes locked up.
I’m gonna take it to a mechanic that’s done some work for me in the past
Old 10-26-2021, 02:08 PM #6
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Lurching typically points to the rear brakes. If your rear drums were warm/hot enough you could have warped them when you entered the water.
belt , braking , deep , felt , squeak
Big puddle. Hydrolocked! What now:( zlasterhazzard 4th Gen T4Rs 12 05-18-2017 08:53 AM
Puddle Problems... bryantd85 5th gen T4Rs 57 05-05-2016 10:18 PM
So I almost got raped by the Dealer today....brakes brakes brakes. DizzyV6P 5th gen T4Rs 36 04-28-2015 11:23 PM
5th gen puddle led light help rig 5th gen T4Rs 4 09-29-2014 09:05 AM
Coolent Puddle tk5150 Classic T4Rs 4 07-01-2010 09:57 PM
