Old 10-24-2021, 09:13 PM #1
fathousecat_ fathousecat_ is offline
fathousecat_ is on a distinguished road
Issues When Turning
Hello,
Just noticed yesterday some issues come up when turning the wheel. The wheel seems to vibrate and make a hum. Just tonight, however, I have noticed a metal sound when turning the wheel. Along with this I have noticed the power steering fluid to be low as well. I believe I have a leak. The leak seems to be right above the steering rack.
Thanks!
fathousecat_ is offline   Reply With QuoteReply With Quote
Old 10-26-2021, 07:32 AM #2
Vansnxtweek's Avatar
Vansnxtweek Vansnxtweek is offline
Vansnxtweek will become famous soon enough
Hello fathousecat,
I think you have answered your own question here. Sounds like you have a power steering leak and it has leaked long enough to potentially have damaged the power steering pump. You could pull back the boots on your steering rack and see if your shaft seals are leaking. If so, you will most likely be best off to replace the rack. The power steering pumps are pretty tough but in the past I have had one that was too far gone and had to replace it. Fill it back up with fluid to the proper level and see if the system works as it should. The fluid will obviously leak out again. The vibrating is air in the system and the metal sound I would guess is a lack of lubrication in the pump.
Hope that helps some.
01' SR5
YouTube: I make 3rd Gen 4Runner videos..among others...
https://www.youtube.com/c/TheChapMX/featured
Vansnxtweek is offline   Reply With QuoteReply With Quote
issues , noticed , steering , turning , wheel
Help needed with brake issues (multiple issues) Terminator03 4th Gen T4Rs 11 10-17-2018 10:26 PM
93 4Runner radio issues and door actuator issues. 128keaton Classic T4Rs 2 05-10-2015 10:11 PM
2015 SR5P Turn Signal not turning off after turning aperture_vision 5th gen T4Rs 10 05-08-2015 05:50 PM
4 wheel turning issues- normal? Calloway 3rd gen T4Rs 5 11-11-2012 10:51 PM
Turning VSC Off in H2 banker1 4th Gen T4Rs 11 02-25-2008 02:08 PM
