10-25-2021, 10:11 PM
Real Name: Eddie
Real Name: Eddie
Does this leak familiar?
Hello All,
This has been happening for some time and I finally got around to trying to discover its source and taking pix.
I originally thought it was the VCG but it sure looks like transmission fluid related and the fluid appears to be tranny fluid.
The upper and lower tranny fluid dipstick tube looks like there is an O-ring between them so maybe that's the source?
Anyhoo, does anyone know of this leak?
Thanks,
Eddie
P.S. The last pic is after I cleaned it with engine degreaser and then rinsed it off.
2001 T4R SR5 - 180k miles and counting.
10-25-2021, 10:14 PM
Sorry, No.
How is the fluid level?
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
10-25-2021, 10:57 PM
only seen the leak at that dipstick pan connect on 2wd's. Needs full pan replacement to correct since the lower stick is one piece to the pan. You can ghetto fix it numerous ways but those are all bandaids...acutally if I don't know the material but you could probably weld and paint to fix.
The leak is usually due to bending and flexing the trans dip stick. Usually this is a result of exhaust/header work...or any other work in that area on the passenger side of the motor since the stick wraps around the exhaust manifolds.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
10-25-2021, 11:11 PM
Real Name: Eddie
Real Name: Eddie
Good, but I find determining the tranny fluid level to be very tricky for some reason. I can't seem to get a clean fluid level indication like I can on the engine oil dipstick.
I will revisit this to be sure it's not overfilled.
Thanks,
Eddie
Originally Posted by nissanh
...How is the fluid level?
10-25-2021, 11:13 PM
Real Name: Eddie
Real Name: Eddie
Yes and I thought it was leaking where the lower dipstick tube connects to the pan, but that means the tranny fluid is moving up the dipstick tube, which sure seems unlikely, right?
Thanks for your comment.
Eddie
P.S. I will thoroughly clean the area and wipe it down to make this troubleshooting effort easier.
10-26-2021, 03:11 PM
Real Name: Patrick
Real Name: Patrick
Thanks,
Eddie
That's a problem with pretty much every transmission dipstick (at least for me). I find the bet way to get an accurate reading is to pull the dipstick out, wipe it off, and put it back in. Repeat that 4-5 times then check where it is on the dipstick. My theory is there is fluid on the higher sections of the dipstick tube caused by the transmission fluid level in the pan rising when you turn the vehicle off.
10-26-2021, 05:53 PM
Use paper towel or shop towel to help you read the level. Wrap it carefully around the dipstick, open it back up and the area with a clear oil stain will show the top of the actual level. The other oil marks higher up on the stick don't really show on the paper towel. Like this:
(engine oil on a Honda dipstick, but you get the idea... it really works, especially after the first dip/wipe)
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
10-27-2021, 01:40 AM
Real Name: Eddie
Real Name: Eddie
Thanks for everyone's replies.
Attached is a pic I took early this afternoon after it sat all night. The pan and tube were cleaned last night.
This is clearly coming from the part of the tube where the upper and lower tube join together so I removed a little over two quarts of fluid and cleaned off the pan and tube and will recheck in the a.m.
Eddie
10-27-2021, 10:04 PM
Real Name: Eddie
Real Name: Eddie
Another update:
After removing about 2 quarts of tranny fluid and check this a.m., there was a minute amount of fluid at the elbow of the tube. See pic.
So I decided to remove about another quart of tranny fluid and will see how it fairs overnight. Updates tomorrow.
I still cannot believe I overfilled this by 3+ quarts and I know for sure I only added what I drained from the pan. OTOH, I can screw up with the best of them so we'll see.
Also, I ordered the O-ring that rests between the upper and lower tranny tube and I'll probably end up replacing that if this latest fluid removal does not work.
Lastly, I have not driven it since the fluid has been removed so that's still an open question even if the leak is no longer a problem.
Eddie
10-27-2021, 11:06 PM
Another update:
Eddie
Have you actually checked where your fluid level is, or are you just going to keep removing fluid until the leak stops and hope you don't pull so much you kill your transmission before then?
10-28-2021, 06:49 AM
I don't mean to be Captain Obvious here but...are you checking the Trans oil using the correct procedure? The level is the level so check the stick correctly and go from there. Hope you get it sorted.
01' SR5
YouTube: I make 3rd Gen 4Runner videos..among others...
https://www.youtube.com/c/TheChapMX/featured
10-30-2021, 01:11 AM
Real Name: Eddie
Real Name: Eddie
Well, the leak has stopped after the last removal of fluid.
I'll double check the procedure to ensure I'm following it correctly.
Thanks for everyone's comments.
Eddie
11-02-2021, 01:03 AM
Real Name: Eddie
Real Name: Eddie
Just an update for those that might find this thread in a search.
I verified the fluid level is where it's supposed to be when hot and double and triple checked it to be sure.
To get it there, I had to add transmission fluid to the tune of ~3.5 qts. Unsurprisingly, the leak is back exactly like it was before.
I suspect the O-ring between the upper and lower dipstick tube has deteriorated to the point of allowing seepage or blowback.
As I said earlier, I have the O ring in question and will replace it ASAP and update the thread.
Thanks all,
Eddie
02-16-2022, 01:07 AM
Real Name: Eddie
Real Name: Eddie
I finally resolved this problem and wanted to post an update for search posterity.
I'm hardly Mr. Goodwrench, but also not a complete knucklehead when it comes to basic car maintenance, but I "assumed" the leak was tranny fluid since it was on the tranny dipstick. I did figure this out not too long after first first post.
Anyhoo, the leak was engine oil from the VCG that was somehow finding a path down the dipstick bracket and downward to the point of accumulating as shown in the pix.
My mechanic replaced the VCG, upper intake manifold gaskets, spark plugs and spark plug tube seals and the cam shaft plugs. It is dry as a bone under my T4R now.
Happy to answer any questions and thanks to those that replied to my initial post.
Eddie
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
