Old 10-27-2021, 04:05 PM #1
Seefral Seefral is offline
Seefral is on a distinguished road
4Runner - Tundra Interchangeability Questions
I recently rolled my 2002 4X4 4runner. 4Runner saved my a$$. No injuries, which is some sort of miracle. Amazingly, 4Runner is still mechanically fine (even the dangling power mirrors I broke off still work). Unfortunately, there's a lot of glass that can't be replaced due to bends in window frames and roof. I had just put a new set of OME nitros in the rear and I have pretty new DuraTracs (LT285/75R16) on 16" "flower" wheels.
I have a chance to buy a 2003 4X2 V6 Std Tundra with a new frame as a replacement for my 4Runner. Same motor as my 4Runner and the Std shift avoids the pink milkshake problem. I did the Tundra brake swap on my 4Runner so I know some stuff that swaps Tundra --> 4Runner. Wondering if my 4Runner OME shocks (front and rear) will swap. Also wondering if the wheels and tires will swap.
I know this isn't a Tundra forum but if any of you guys have any ideas I'd appreciate some feedback. Even if it's just to point me to a good Tundra forum.
Seefral is offline   Reply With QuoteReply With Quote
Old 10-27-2021, 04:57 PM #2
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Front suspension components should swap over, not sure about the rear, wheels and tires should also swap. Could probably use the 4Runner parts to do a 4x4 swap, I’m pretty sure the front diff is the same and the transfer case should bolt up to your transmission
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 10-27-2021, 05:03 PM #3
Rear shocks will be too short and stiff for the Tundra.
4x4 swap will need longer Tundra axles, but otherwise might be an interesting project... The transfer case probably isn't a direct bolt-on either (Tundras were electric shifted with no holes in the floor normally, I believe - might work better with a manual Tundra though)
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-27-2021, 05:12 PM #4
I think you’re right about the the electronic shift but from a quick google search it looks like manual tcase swaps on tundras are a thing and probably not that hard. A J shift tcase should be really cheap from a junkyard or part out. The knuckles are the same between the tundra and 4Runner so you could swap those over too
I assume the op is in a rust state based on the tundra having a new frame so that’s a big plus, I say get the tundra if it’s a decent deal
Old 10-27-2021, 05:36 PM #5
Thanks!
Old 10-27-2021, 05:37 PM #6
Thank you!
Old 10-27-2021, 05:52 PM #7
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
4runner front shocks are shorter than tundra shocks and a different tophat. 4Runner rear shocks are shorter/stiffer and also have a different bushing at the axle. Wheels and tires will swap over.
Old 10-27-2021, 06:32 PM #8
busmup808's Avatar
busmup808 busmup808 is online now
busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough
busmup808's Avatar
The front shocks and coils are interchangeable, but the top hat will need to be swapped out for the tundra. The top hats are different from 4runner and tundra/sequoia. Front tundra calipers are interchangeable as well. If the tundra is a 2wd, you might have the 199mm smaller calipers on there. The 231mm is the ones came in the TRD and LIMITED packages. Rear shocks are lower on the 4runner and taller on the tundra. Unfortunately your rear 3rd member cannot bolt to your tundra axle being that its bigger on the tundra.
Personally I would cab swap that 4runner if you did a lot of work to it. Good luck with your decision.
Busmup808 all day, all night!
busmup808 is online now   Reply With QuoteReply With Quote
4runner , ome , rear , swap , tundra
3rd gen 4runner using 2006 tundra steelies questions Jasonredwood 3rd gen T4Rs 5 08-11-2013 10:19 AM
TRD Tundra lift questions. HELP obxfunrunner 3rd gen T4Rs 2 12-27-2012 09:59 AM
2006 tundra-2004 4RV6 parts interchangeability? Athabasca 4th Gen T4Rs 0 01-10-2011 08:05 PM
Tundra questions Supra725 General Discussions 7 12-24-2010 09:34 PM
