Old 10-28-2021, 07:49 PM #1
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Trans oil levels with modified cooling
*****EDIT******* I had it backwards. The fluid registers correctly when Hot, but is way above the Hot line when the truck is actually Cold.
Extra cooling via a Tru-cool in series, extra hose loop, Magnefine etc.
Old 10-28-2021, 08:12 PM #2
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
The fluid expands when it warms up which is why it reads higher when hot. The added plumbing has added fluid capacity, but it hasn't changed where you want the dipstick to read. The FSM is pretty clear that the cold reading is to get you into the right ballpark when refilling, but the hot reading is the one you want to actually use to make sure you have the right amount of fluid.
Skulking is offline   Reply With QuoteReply With Quote
Old 10-28-2021, 08:14 PM #3
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
When you measure the fluid level on the dipstick you're measuring what's in the pan not the whole system.
After installing an external cooler continue to measure the same way as before.
The cold level is just to get you in the right ballpark.
It should not be used to determine if you have the correct amount of fluid.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 10-28-2021, 10:49 PM #4
Real Name: Blair
Real Name: Blair
OK, thanks all. I may have added a little more than I should have after doing all the plumbing. After installing the cooler I've run it harder than ever before - some Rubicon trail, some Mojave desert, mountains, etc. Hope I haven't done any damage....
Old 10-29-2021, 08:56 AM #5
19963.4lsr5 19963.4lsr5 is online now
At the end of a 10+ mile drive, drain the atf and add 1 gallon.
Start it up run it through the gears and put back in park with engine running check your level.
I don’t even pull the dip stick anymore.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 10-31-2021, 04:32 PM #6
Real Name: Blair
Real Name: Blair
Oops - just clarifying my mistake so future searchers don't get the wrong idea.
Old 11-01-2021, 08:11 AM #7
This is with engine running correct?
Old 11-01-2021, 09:00 AM #8
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
The cold level is to get it in the ballpark in order to run the transmission to get hot without damaging it. A high cold level with the engine running is not a problem.
capacity , cold , fluid , hot , system
Upgrade on the trim levels Dollar Retriever 5th gen T4Rs 1 12-04-2020 12:26 PM
Aftermarket radiator with integrated trans cooling - replace fittngs? Endlessblockades 3rd gen T4Rs 5 06-16-2020 01:19 PM
engine and Auto trans cooling question Dezerts10 3rd gen T4Rs 24 01-03-2018 10:04 AM
Big Levels, VA on April 2nd brianhuntRVA Off-Roading 2 03-26-2016 08:25 AM
