Old 01-22-2022, 10:34 PM #1
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Factory wire harness question
Are the harnesses installed per model year the same for all models/trim levels?
Seems like it would be for economy sake in manufacturing from the factory, but the reason for the question:
If you wanted to install an e-locker rear diff, is the wiring already there?
If you wanted to install factory fogs (in the bumper) on a base model (assuming you replace the switch assembly on the column, too), is the wiring already there?
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 01-22-2022, 10:46 PM #2
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
No, they are not. There may be some common wiring between different trim levels, like you may find that some plugs for stuff that isn't there, but they don't wire the engine wiring harness for both 4cyl and 6cyl or the dash wiring harness for both auto and manual climate control or the body harness for both heated power seats and manual non heated seats.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 01-23-2022, 08:57 AM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
They used to be this way in the 80s but not in the 3rd gens. You have to match the harness part numbers to get the same harness. They are different . So always match the engine harness to the chassis.
For example: I put a 1998 engine in a 1997 limited. I swapped the engine harness to match the 1997 chassis because they had a few slight differences.
The change from one harness all models was probably done to save costs in mfg. I was majorly bummed when I found this out as I liked to plug in the accessories that were missing from other vehicles that had then.
So the changed happened in the 80s at some point. At least on the main body harness. My guess is when the EFI went in as their wiring wasn't there in the carbonated models..
Old 01-23-2022, 12:54 PM #4
spartacus's Avatar
spartacus's Avatar
If you have the factory black plug behind the kick panel under the steering then you have the abs+wiring in your truck all you would need is the LROR wiring harness to run it to the locker.
Most all 4runners have the wiring in place for the fogs. you'll have to swap out the non fog stalk for one with the fog switch on the stalk , install the relay and the fuse. For anytime fogs a dash mount switch would have to be spliced into a power source or ignition on circuit.
Old 01-23-2022, 08:08 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The 1996 to 1998 do not have any wiring for fogs. They were dealer add on. just like the rear hitches were an add on..
Old 01-24-2022, 05:45 PM #6
(this is all for 99+) The harnesses are somewhat piecemeal. The front fender harness is the same for all of them - you can find the plug for the Limited outside temp sensor on an SR5, and they all have wiring for the fogs, etc. The wiring for the temps sensor isn't on the dash harness though, because the Limited has so many other differences for the auto-ac. My 2WD had the plug for the ADD relay. Most 4Runners will not have the locker-capable driver's side interior harness, but some did, etc. Basically each harness section has a couple options and they were put together in different permutations.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-25-2022, 12:54 PM #7
What about heated side mirrors?
What determines if the wiring is hot?
Sent from my Pixel 4 XL using Tapatalk
Old 01-25-2022, 01:48 PM #8
whl215 whl215 is offline
whl215 is on a distinguished road
Nope
There are proprietary harnesses for each model and year. It would be too easy if they had the same...
2020 4Runner Limited:
Rapture Lights, DD Headlights, Bights & Fogs (Yellow), DD Turn as Tail, Red Map lights, Blue door lights, LED Hatch lights. GOBI rack on order!
whl215 is offline   Reply With QuoteReply With Quote
factory , install , model , wanted , wiring
Adapting a 3-wire gear driven VSS to a 2-wire electronic VSS harness? derekwilliams345 3rd gen T4Rs 10 01-11-2021 02:11 PM
Trailer wire harness routing question. wrpsuite 3rd gen T4Rs 1 05-25-2015 09:07 PM
3rd Gen Radio Wire Harness Question/Problem Smalss Engines / Suspension / Wheels / Tires / Audio / Accessories 16 07-06-2014 10:55 PM
factory hitch harness wiring (what is this wire?) hawkcharmer 3rd gen T4Rs 0 07-29-2013 06:24 PM
Installing all new speakers with external amp..run wire through factory harness??? kickinasphalt Engines / Suspension / Wheels / Tires / Audio / Accessories 5 04-23-2007 07:32 AM
