Old 11-01-2021, 04:53 PM #1
jman11788's Avatar
jman11788 jman11788 is offline
jman11788 is on a distinguished road
jman11788's Avatar
Heater control valve issues
Recently I had to replace the heater control valve when I installed the supercharger cause the part basically broke like they normally do at 20 years old. After replacing I didn't even test the heat cause my mind was focused on other things of course
Now that the cold weather is back the heater will not work unless I manually move the cable all the way towards driver side. Air will go back to cold and back to hot with vehicle running. After I re start the vehicle no more heat?
Also there is a water gurgling noise behind dash when I drive. Tried bleeding the coolant system but to no avail.
2000 Limited 4wd Supercharged with E-Locker
jman11788 is offline   Reply With QuoteReply With Quote
Old 11-01-2021, 05:12 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Try using a spill free funnel (Amazon.com: OEMTOOLS 87009 No-Spill Coolant Funnel Kit, Near Universal Fitment, Translucent, 15 Piece Set, Cooling System Funnel Allows Access To Hard-To-Reach Radiators : Automotive) and elevating the front end as much as possible when you bleed the cooling system. The gurgling noise you hear is air in the system.
EDIT: Forgot to add to make sure you turn your front and rear heat on (if you have rear heat).
Old 11-01-2021, 11:34 PM #3
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Just elevate with ramps or an incline and keep adding. May take a few times to get full. I’m sure the special funnel works awesome.
As far as no heat goes, you could have clogged heater cores front and rear(if equipped). Pretty common failure due to the design of the system. The $50 OTC flush gun makes short work of that task if a power flush is needed. Both of my cores were plugged solid.
I don’t know why people think coolants are a lifetime fill……
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
back , cold , control , heat , heater
Heater Core Valve Issues DreadPirateJon 3rd gen T4Rs 6 02-28-2021 07:56 PM
Heater Control Valve la79 3rd gen T4Rs 10 04-01-2020 10:45 PM
Heater control valve thegipper 3rd gen T4Rs 13 12-28-2019 02:10 PM
WTB 3rd Gen (1996) Heater Control Valve CB3G_GM Want to Buy/Trade 3 12-10-2017 10:21 PM
heater control valve failed (pic's) tyr0981 3rd gen T4Rs 22 04-30-2015 07:44 PM
