Old 11-02-2021, 03:07 PM #1
SgtAbn's Avatar
SgtAbn SgtAbn is offline
Real Name: Jerry Kraus
SgtAbn is on a distinguished road
SgtAbn's Avatar
3rd Gen Lift Install Question Please?
Did any of you install longer sway bar end links or longer tie rod end links after installing your lift? I only did a 3" lift and I was able to get them re-attached but the angel of them is a little off now....
2002 T4R Limited 4x4 w/factory locker, factory supercharger, sunroof, deck plate mod, Tundra brake upgrade, BFG TA/KOs on 17" TRD rims, automatic transmission, 3" lift from Toytec with "Old Man Emu" heavy duty shocks & springs, 288,000 miles on it, I live outside Steamboat Springs, Colorado.
SgtAbn is offline   Reply With QuoteReply With Quote
Old 11-02-2021, 03:24 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
You can use these fancy ones: Forged Ball Joint Sway Bar Links
– Overland Custom Design
or for a more budget friendly approach: https://www.toyota-4runner.org/3501009-post2.html
Old 11-02-2021, 03:32 PM #3
A 3" lift is at the max of the range for stock front (and rear, really) geometry. You lost a lot of droop travel, especially with stock upper a-arms. It isn't "only" at 3"... If you want a 3" lift, a better plan is 1" body lift and 2" suspension lift. More clearance, better geometry, better articulation, same looks.
You'll probably slightly longer front swaybar links, but the tie rods should be fine - the angle they are at needs to match the lower arms, so they will look off at such a high ride height.
Make sure you get an alignment done. If you still have the stock upper a-arm, they won't be able to make it correct, but they can try to get it close.
Oh, and get new OEM lower ball joints on there ASAP if you haven't replaced them recent. And get ready to need new axles (or just boots) too.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-02-2021, 03:35 PM #4
spartacus's Avatar
spartacus's Avatar
Use the existing fronts in the back and put the 2nd gen rear links which are about an inch longer in the front.
Old 11-02-2021, 04:45 PM #5
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
I really like how stout the overland custom design ones have been. I’ve beat the hell out of them and they’ve held well.
I went with the sealed ball joint style, plus you can order individual pieces in the future of needed.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
end , install , lift , links , longer
A question for when I install my lift. Signal 5th gen T4Rs 14 05-15-2020 06:38 PM
Air lift install question jpachard 5th gen T4Rs 10 03-08-2018 06:17 PM
Very simple lift install question toyoKühl 3rd gen T4Rs 3 03-05-2014 12:48 PM
Lift question before install tomorrow durrell 3rd gen T4Rs 30 01-30-2011 12:51 AM
Question before I install lift kit. ron70062 3rd gen T4Rs 6 01-30-2008 05:17 PM
