11-08-2021, 08:40 AM
#16
Originally Posted by Devbot
FYI, starting your car and not letting it get up to temp is not helping your cat. In fact that's how you hurt them
I plan on putting in a straight pipe through. that cat is only impeding airflow at this point
11-08-2021, 08:43 AM
#17
Originally Posted by DenverAirport
Did you notice coolant leaking near the top of the engine compartment / near windshield? I had this happen to me when my heater control valve exploded.
It was dark and raining at the time. + by the time we stopped there was coolant everywhere since it had boiled/popped out the coolant capture reservoir thing so hard to say.
but my heat does not work... I dont know how long its not been working.
11-08-2021, 10:05 AM
#18
When ones heater stops blowing hot air, that is a great indicator you’re low on coolant.
11-08-2021, 10:17 AM
#19
Coolant has been topped and no signs of leak since the incident.
Heater has never worked since I bought it 3k miles ago.
11-08-2021, 11:11 AM
#20
Have you checked your cooling fan?
18 Audi A6 3.0T - APR Tuned, RS6 Interior 19 Audi A6 3.0T
11-08-2021, 11:51 AM
#21
radiator fan sucking in air real good.
11-08-2021, 01:16 PM
#22
Right. How's the clutch? Do you know how to check that?
11-08-2021, 03:47 PM
#23
Real Name: Jerod
Real Name: Jerod
Heater never worked? So there's coolant passage issues pre-dating you ever owning it. All the heater system is comprised of is a valve, some tubing and a radiator with a fan behind it. Sounds like your cooling system is in dire need of help from top to bottom.
11-08-2021, 04:37 PM
#24
Negative, but google search says give it a spin and there should be some resistance ?
So youre saying my heater issue could be linked ?
Should I start with replacing the valve ?
making a big ol RockAuto shopping cart right now..
Cooling System : Radiator Hose
Cooling System : Radiator Cap
Cooling System : Thermostat
Cooling System : Thermostat / Thermostat Housing / Water Outlet Seal
Heat & Air Conditioning : Heater Valve
11-08-2021, 04:45 PM
#25
Real Name: Jerod
Real Name: Jerod
It could all very much be linked. Any coolant leak, even if not from the engine, will affect coolant fluid pressure and circulation and have a negative affect on cooling ability. It's hard to diagnose something over the internet without seeing your vehicle so I cannot say with any certainty. You did the HG test which came out good so that's a positive, that's the hardest job to do. You can now narrow it down to either a faulty hose, water pump, or heater core as the mystery leak.
Some auto parts stores will let you rent tools, including a coolant system pressure kit. It comprises of a universal fit radiator cap and a hand pump with a pressure gauge. You pump in some air to a set PSI and watch and listen for any leaks. It's not a definitive test as it can still leak when the engine is really hot but not cold when you do the test but it can help and is free.
This is the one I own: Radiator Pressure Tester Kit
11-08-2021, 06:09 PM
#26
I'd highly suggest an OEM thermostat and OEM radiator cap. And make sure the radiator is a quality one.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
11-08-2021, 08:37 PM
#27
You need to narrow down the problem before you go buying a bunch of parts. Pressure test the coolant system and check the fan clutch first. The heater issue could be completely unrelated, like a clogged core or a stick blend door even.
11-08-2021, 11:37 PM
#28
I agree...that said, depending on how many miles are on the parts, there's nothing wrong with being proactive and replacing the radiator / cap / hoses / flush coolant / heater control valve. May not fix the problem but wouldn't be the worst things to replace.
In terms of the truck's heater not working -- flushing the heater core isn't a bad idea either and is easy enough with a garden hose.
I noticed later on that there was a post yesterday after you posted this about heater control valves actually. Here's a good video on the topic:
How To Replace A Heater Control Valve On A Toyota - YouTube
99' SR5 "Highlander Edition" - 301k - 4WD, Factory rear locker, 2.5" Dobinsons IMS lift, SPC UCAs, CJV 9168 TR axles, 199mm TBU, Tom Wood's driveshaft, eimkeith PCK, Aluminum Koyorad, Ultragauge
97' Limited - 250k - Stolen & Found (and Sold) - 4WD, 3" Billstein 5100 lift with OME 881, 890 springs, Diff drop, Camburg UCA's, 231mm TBU, Tom Wood's driveshaft, eimkeith PCK, Champion radiator, Ultraguage
11-13-2021, 04:05 PM
#29
Compression test results:
1: 199
2: 116
3: 179
4: 189
5: 199
6: 186
And pic of Cyl 2 spark plug
Now how do i know if i need to replace heads or just the gaskets ?
11-14-2021, 10:31 AM
#30
116 is no good. I'm not sure a head gasket or head would cause 1 cylinder to be so low compared to the others, could be rings. Let see what others think.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Overheating again...
Atreyus |
3rd gen T4Rs |
97 |
03-22-2021 01:55 PM |
Overheating
Tahoe4runner |
Problems & Warranty Issues |
2 |
02-22-2014 07:10 AM |
overheating 3.4
brianstormchaser |
Engines / Suspension / Wheels / Tires / Audio / Accessories |
3 |
10-30-2013 02:44 PM |
overheating?!?!?
4runnernoobie_89 |
Classic T4Rs |
10 |
04-19-2011 04:06 PM |
Overheating
Hawkdog21 |
5th gen T4Rs |
7 |
09-21-2010 07:24 PM |
