Old 11-14-2021, 03:06 PM #31
Cree's Avatar
Cree Cree is offline
Cree will become famous soon enough Cree will become famous soon enough
Cree's Avatar
Originally Posted by tpelletier View Post
Compression test results:
1: 199
2: 116
3: 179
4: 189
5: 199
6: 186
And pic of Cyl 2 spark plug
Now how do i know if i need to replace heads or just the gaskets ?
The color near the base of the strap shows burning coolant. My money would be on a head gasket. No really good way to tell without tear down. You'll see the failure point on the gasket. If you don't, you'll want to get the head fluxed. If your oil is free of water, it's going to be either the head or the gasket MOST LIKELY. Typically if a cylinder cracks you'll get water in the oil.
00 Limited - Stuff!
18 Audi A6 3.0T - APR Tuned, RS6 Interior
19 Audi A6 3.0T
Cree is offline   Reply With QuoteReply With Quote
Old 11-14-2021, 03:47 PM #32
spartacus's Avatar
spartacus's Avatar
It could be the gasket but usually two adjacent cylinders show weak compression numbers.I could be wrong.
Pour a tea spoon of oil in #2 if you get higher compression then the rings could be the culprit. If the compression numbers don't increase much then it could be burnt exhaust valve, or intake valve due to overheating.
Unfortunately removing the heads and examining would be the only way, IMO.
Old 11-14-2021, 07:04 PM #33
tpelletier tpelletier is offline
tpelletier is on a distinguished road
Alrighty, Ill check the oil for water and do that oil test.
In the meantime I am ordering a full gasket kit on Rockauto.
Question: If I am opening up the heads, should I might as well replace the problematic head as well ?
Thanks again y'all
tpelletier is offline   Reply With QuoteReply With Quote
Old 11-15-2021, 09:51 AM #34
spartacus's Avatar
spartacus's Avatar
Thanks again y'all
If the head is flat no cracks it should be good. But getting it skimmed is an option that might be cheaper then buying a new head. I dont know cost wise what would be better. Call machine shops near you that do head resurfacing.
Old 11-15-2021, 09:55 AM #35
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
1: 199
2: 116
3: 179
4: 189
5: 199
6: 186
Do a cylinder leak down test on cylinder number 2 with a cold engine and the radiator cap off. It's possible to have a failed head gasket where it fails between the cylinder and a coolant or oil passageway and only affect one cylinder.
Old 11-15-2021, 11:11 AM #36
The 97 SR5 project was that way. One cylinder with antifreeze pooled in a cylinder.
On a side note….since I bought the 97 knowing it’s engine was toast, I just pulled it and put it on a stand and pushed it into a corner. Big mistake. The antifreeze in the oil pan caused both intake cams to rust before I broke it down to rebuild. It sat almost two years. I won’t do that again.
back , engine , radiator , sealant , temp
Overheating again... Atreyus 3rd gen T4Rs 97 03-22-2021 01:55 PM
Overheating Tahoe4runner Problems & Warranty Issues 2 02-22-2014 07:10 AM
overheating 3.4 brianstormchaser Engines / Suspension / Wheels / Tires / Audio / Accessories 3 10-30-2013 02:44 PM
overheating?!?!? 4runnernoobie_89 Classic T4Rs 10 04-19-2011 04:06 PM
Overheating Hawkdog21 5th gen T4Rs 7 09-21-2010 07:24 PM
