Old 11-29-2021, 03:03 AM #1
bryanbgw's Avatar
bryanbgw bryanbgw is offline
bryanbgw is on a distinguished road
bryanbgw's Avatar
Falken Wildpeak AT3 - Air Down PSI for Snow/Washboard?
Hey all,
I have a new set of Falken Wildpeak AT3's on my 3rd gen 4runner, currently with the 16" alloy 5-star stock rims.
  • What PSI should I run in snow?
  • What about washboard (25-30mph)?
  • Lowest/safest PSI?
  • Daily driving PSI?
Thanks all,
bryanbgw is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 12:04 PM #2
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
  • What PSI should I run in snow? 15-20 psi
  • What about washboard (25-30mph)? 15-20 PSI
  • Lowest/safest PSI? 12-14 PSI depending on actual tire size and wheel width. Wider tire on a narrow rim is more likely to lose the bead.
  • Daily driving PSI? - Look up the "Chalk Test" - no other way to know.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 12:23 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I don't know where you got that from but wider tires on narrow wheels are much less likely to lose a bead. Rock crawlers have been using that combo below 10 psi for decades without an issue.
Old 11-29-2021, 12:36 PM #4
shadow247's Avatar
shadow247's Avatar
285's on a 7.5 inch rim are definitely a concern for losing the bead at 12-14 PSI. I have personally witnessed a few debeadings on stock wheels with that size. I have no issues on the same wheels with 265 vs 285's.
I get what you are saying about rock-crawlers. Ideally the width of the rim is within an inch of 2 of the tire, and yes, the rim does benefit from being slightly narrower, but there's a break even point for that.
The 4Runner Show
Old 11-29-2021, 12:48 PM #5
Real Name: Patrick
Real Name: Patrick
To clarify stock 5 star wheels are a 7 inch wide wheel. The closer the wheel width to the tire width the more likely you are to lose the bead. That's been my experience and observation. Sidewall height also plays a role in the bead retention.
Old 11-30-2021, 09:54 PM #6
bryanbgw's Avatar
bryanbgw's Avatar
Well the tire size is 285/75/R16.
Wheel size is.. sounds like 7in.
I should be good for the recommendations Shadow provided?
Old 11-30-2021, 10:41 PM #7
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
I have personally witnessed that going down to 20 psi helps make washboard feel smoother. I have no experience airing down on snow/ice, however.
pluton is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 11:55 PM #8
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Originally Posted by bryanbgw View Post
Hey all,
Thanks all,
I have the 17"*7" stock sr5 rim on 285/70/17s. On the trail I don't go lower than 15 pounds never had a bead problem, not even close. In the snow my usual because I go hardcore through it and enjoy the danger factor. Normal road conditions depends on your driving style around corners. I like to go hard with my wheel spacers wide stance. So you'll be paying attention to sidewall stiffness/roll around corners and adjust to liking. For me this is 42 pounds.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
25-30mph , daily , falken , psi , wildpeak
Falken Wildpeak 275/70/17 LT Xetabur For Sale: Suspension/Wheels/Tires 3 09-11-2020 12:15 AM
New Falken Wildpeak M/T Konkordmusk 3rd gen T4Rs 16 01-06-2020 01:06 PM
WTT Falken Wildpeak 265/75/16 for your 285’s Bmthompson10 Want to Buy/Trade 1 11-07-2019 03:28 AM
VA - Falken Wildpeak A/T3W - 265/70/17 (4) shyuperman For Sale: Suspension/Wheels/Tires 2 10-09-2018 09:38 AM
Falken wildpeak at3 Rudeboy706 3rd gen T4Rs 6 05-30-2017 06:49 PM
