Old 11-06-2021, 05:29 AM #1
airdreams1 airdreams1 is offline
airdreams1 is on a distinguished road
P420 code....
Was pretty sure I had a leaking fuel injector. So I replaced the injectors with six remanufactured ones. The check engine light came back on again for the same code. Now I'm wondering what else might be the issue. Obviously could be the oxygen sensor or catalytic converter. Is there anything else that it could possibly be?
airdreams1 is offline   Reply With QuoteReply With Quote
Old 11-06-2021, 01:03 PM #2
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
In my case, an exhaust leak downstream from the cat (beyond the flange, on a self-installed exhaust system) caused the P420. Worth checking your connections beyond the second 02 sensor - you might get lucky.
Old 11-06-2021, 03:46 PM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Yup exhaust leak will trigger it.
On mine and some others on here, its been reported usually when off-roading traveling 5 or so mph for a couple miles or more will also trigger the 420. Mine does it like clockwork under this condition only, I can then clear the code and drive hundreds of miles city and/or highway and no 420.
I just clear it and drive an hour or so before each annual safety check and it passes. Luck.
Old 11-07-2021, 10:40 AM #4
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
Make sure engine has the correct duel ground electrode spark plugs in good condition, a clean air filter and is running well first. Next check the exhaust system for leaks near the converter and downstream O2 sensor. I find that leaking flex pipes, worn out flanges, blown out gaskets or small holes where heat shields, hangers, etc were welded on the exhaust are the most common cause of P0420 on most vehicles. If you bang on the converter and hear something rattling around or view you engine data on a code reader and the downstream O2 sensor mimics the upstream sensor you need a converter. Could also be caused by bad O2 sensor or MAF sensor.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
code , issue , p420 , sensor , wondering
Code help please mavrick1903 4th Gen T4Rs 16 03-09-2021 06:17 PM
P420 P430 Help! Run4nuts 4th Gen T4Rs 8 08-09-2016 05:01 PM
P420 01thunder 3rd gen T4Rs 5 07-17-2016 03:20 PM
Check engine light on: Code 24 and code 31 Clone of the Mean Classic T4Rs 3 06-19-2011 12:12 PM
