Decided to put everything together for a true test....
I have hot hot air now!
HOWEVER, I turned on the AC.....I still have hot hot air....and a loud buzz noise coming from the passenger footwell...its the servo motor....makes sense now why it was disconnected.
It does move as I stated in another post...but connected up it makes a noise...so I assume that part is bad? Unless something else is jamming before it. What do you think, buy the part?
I did call autozone and o'riely's yesterday about this part and its on back order everywhere. I can get it new on ebay.
Before I buy the servo motor is there anything else that could be jamming it or causing that noise? When i connected the servo motor via the electric plug it moved fine, no noise. Not sure what the noise means...is it jamming or is pulling the cable too much of a load?
I thought the plastic gears look fine when I looked at it before...I will look again.
Found this....
Strange buzzing sound from cabin
