I'm assuming the ADD system is still intact and functioning? That disconnects the passenger side CV shaft from it's spider gear in the trans. Normally, this lets the driver side "almost" freewheel as well, but the CV shaft will still be spinning the spider gear. And normally, that's where it stops. The spider gears spin, and the diff carrier/ring and pinion/front driveshaft don't turn.
But with an LSD/non-switchable locker diff in the front, the driver side wheel will still be spinning the diff, and thus the driveshaft as well. But the passenger wheel will still be disconnected.
You might need to either:
- disable the ADD system so both front wheels are 'engaged' and have equal drivetrain drag
- use a selectable front locker that can operate as a completely open diff when not in use
- or add manual hubs
