Old 11-09-2021, 03:06 PM #1
DJRodriguez88 DJRodriguez88 is offline
DJRodriguez88 is on a distinguished road
drag on front driver side wheel
recently regeared installed detroit locker up front
the car has been pullin left quite a bit so i took it for an alignment today
the alignment guy suspects a problem with tcase or diff causing a "drag" on the front drivers side wheel since there isnt evidence of a dragging caliper or bad wheel bearing.
with the wheels in the air, in 2wd, if you spin the front driver wheel by hand it is noticeably heavier to turn than the passenger. you can also see that the front drive shaft spins along with the front driver side wheel. the front passenger wheel spins by itself with much less effort.
im not stuck in 4x4 bcuz the front wheels spin with the rears on the ground
what else can cause this kind of behavior?
DJRodriguez88 is offline   Reply With QuoteReply With Quote
Old 11-09-2021, 04:33 PM #2
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
I'm assuming the ADD system is still intact and functioning? That disconnects the passenger side CV shaft from it's spider gear in the trans. Normally, this lets the driver side "almost" freewheel as well, but the CV shaft will still be spinning the spider gear. And normally, that's where it stops. The spider gears spin, and the diff carrier/ring and pinion/front driveshaft don't turn.
But with an LSD/non-switchable locker diff in the front, the driver side wheel will still be spinning the diff, and thus the driveshaft as well. But the passenger wheel will still be disconnected.
You might need to either:
- disable the ADD system so both front wheels are 'engaged' and have equal drivetrain drag
- use a selectable front locker that can operate as a completely open diff when not in use
- or add manual hubs
JohnMc is offline   Reply With QuoteReply With Quote
driver , front , side , spins , wheel
Grinding Front Driver's Side Wheel modelstudent101 3rd gen T4Rs 3 10-20-2016 02:26 PM
Driver side front and rear lower than passenger side! gyro09 3rd gen T4Rs 3 07-14-2016 04:21 PM
Grinding in front driver side wheel! 91denver4runner Maintenance/Detailing 2 11-19-2012 08:59 PM
Driver side versus Passenger side front coil heights terrytcl 3rd gen T4Rs 5 02-28-2012 07:06 PM
Clicking noise on the front driver side wheel Juank303 Problems & Warranty Issues 1 07-13-2009 01:08 AM
