Old 11-12-2021, 12:09 PM #1
eurasiaoverland eurasiaoverland is offline
eurasiaoverland is on a distinguished road
Moonroof disassembly / adjustment in FSM
My 1996 3rd Gen has been sitting outdoors for almost two years and a previously operative moonroof is not seized (and leaking). The leak has been addressed but I am still tackling the seized drive cables.
I've removed the head lining and have the moonroof assembly out on the bench, but it's not clear to me how to dismantle and then set the position of the cables and motor once they have been cleaned / replaced.
Would anyone be able to post a few sides of the FSM, I've never managed to find on for the vehicle (always used Tacoma / T100 FSMs but they didn't have a moonroof). I think it's pages BO-54 to BO-58 approximately.
Thanks
EO
1993 Hilux 2L diesel manual - in storage.
1996 Hilux Surf 3RZ-FE manual - overland vehicle (and rolling restoration).
1989 Landcruiser BJ60 - undergoing full restoration and engine transplant.
Over 250,000 kilometres around Eurasia in Toyota trucks: http://eurasiaoverland.com/
eurasiaoverland is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 01:19 PM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
These links should help, not sure about some of the YT techniques but gives you a few ideas.
1996 4Runner sunroof fix - YouTube
http://www.teamtoyota4x4.org/archivi...liroo/disa.pdf
http://www.teamtoyota4x4.org/archivi...liroo/adju.pdf
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 02:03 PM #3
Thanks, the pdfs are helpful. I saw some pages from the 3rd Gen FSM here: Write-up for the moon roof/sunroof motor replacement
But it skips the adjustment procedure.
I still think there is some adjustment with the marks on the tops of the sliding rails, and the mark mentioned on the moonroof motor.
Old 11-14-2021, 03:30 AM #4
Malcolm99's Avatar
Malcolm99's Avatar
BO-62 describes that, diagram N11160.
fsm , moonroof , post , replaced , sides
moonroof delete/removing moonroof? Vtwinracersp2 5th gen T4Rs 23 09-11-2018 03:23 PM
Moonroof or not to moonroof; that is the question! PauldF 5th gen T4Rs 74 04-17-2018 03:41 PM
Air bag disassembly 97t4r81 3rd gen T4Rs 9 06-21-2015 04:20 AM
Seat disassembly help mgede 5th gen T4Rs 2 04-15-2014 07:42 AM
Wheel bearing went out, need help with disassembly Tayzorz 4th Gen T4Rs 11 01-21-2014 10:54 AM
