Originally Posted by SaxAndLiz
Trying to figure out what’s causing all this leaking. The fluids seem oily. Please help. If you need me to take more pics or do other tests I am happy to do so. Thanks!
That leak is everywhere and there are too many things in that area that could be the culprit. In order for us to accurately help you you're going to need to clean most of that off. Once you clean it off, drive a couple miles and check back for leaks. The more often you check the better off you'll be.
Also check your transmission fluid level and power steering fluid level. If either of those are low then it's a helpful clue.
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
