Old 11-12-2021, 03:42 PM #1
SaxAndLiz SaxAndLiz is offline
SaxAndLiz is on a distinguished road
Fluid leakage. See pics.
Trying to figure out what’s causing all this leaking. The fluids seem oily. Please help. If you need me to take more pics or do other tests I am happy to do so. Thanks!
SaxAndLiz is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 04:17 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
That leak is everywhere and there are too many things in that area that could be the culprit. In order for us to accurately help you you're going to need to clean most of that off. Once you clean it off, drive a couple miles and check back for leaks. The more often you check the better off you'll be.
Also check your transmission fluid level and power steering fluid level. If either of those are low then it's a helpful clue.
Old 11-12-2021, 04:23 PM #3
Thanks, that was going to be my next step. I checked the dipsticks for power steering and transmission, both are fine. I guess it’s time to bring out the brake cleaner and wipe it all down.
Old 11-12-2021, 04:40 PM #4
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Inspect your valve covers, specifically, the backside near the firewall. It is common for the valve cover gaskets and/or half moon plugs to leak over time resulting in oil leaks like you are seeing.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 05:23 PM #5
This. Suspect the valve cover first. If it is wet up top, repair, clean then see if there are any other leaks.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-12-2021, 05:34 PM #6
Thanks. The oil level was lower than usual when I changed it last month. I check levels regularly between oil changes. These sound like they are at top of the engine, so look at from under the hood?
Old 11-12-2021, 06:08 PM #7
Real Name: Patrick
Real Name: Patrick
You'll have to look from underneath at the firewall side of the cylinder heads.
fluid , happy , ipad , pics , tests
water leakage ?? Paramedic 3rd gen T4Rs 3 08-16-2016 11:57 AM
Can anyone identify this...leakage? scrapper 3rd gen T4Rs 14 11-15-2015 03:54 PM
Oil Leakage Concern cbielat 5th gen T4Rs 11 05-29-2012 09:27 PM
Front/rear differential fluid, trans fluid and transfer case fluid change 88 Kel Varnsen Classic T4Rs 1 05-20-2012 03:26 AM
