Old 11-15-2021, 03:59 PM #1
Chris_Overland's Avatar
Chris_Overland Chris_Overland is offline
Chris_Overland will become famous soon enough
Oil filter replacement after I've already filled with oil?
TLDR; Can I replace my oil filter without spilling a ton of oil everywhere even though I've already filled it up?
This is what I get when trying to replace all the fluids in the rig at one time. I drained/refilled the engine oil then realized I didn't change the oil filter. Is it possible to swap them out without draining the oil out? Or am I asking for a huge ass mess?
1999 Imperial Jade Mica Limited
Bilstein 5100 & OME 881/891
SpyderTrax 1.5 spacers
Tundra brake upgrade
238,000 and still kickin
Chris_Overland is offline   Reply With QuoteReply With Quote
Old 11-15-2021, 04:05 PM #2
nissanh nissanh is offline
Engine off: yes, simple to remove and replace. Oil inside the old oil filter will come out, nothing more. Glad you didn't the other way around!
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 11-15-2021, 04:20 PM #3
Sweet thanks!
Old 11-15-2021, 05:06 PM #4
Get a form-a-funnel and wedge it below the filter, which will catch and route the oil to the drain pain of your choosing. You'll need to re-fill with 0.5 quart or less of oil after the filter change.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-15-2021, 05:44 PM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
To clarify for the OP, you only need to add extra oil if you have started the engine since you drained and filled with new engine oil. If you haven't started it since new oil has been put in then you don't need to add any oil.
filled , filter , oil , realized , replace
Fuel Filter Replacement deltaclothingco 4th Gen T4Rs 11 01-15-2012 10:50 AM
K & N replacement filter Shanesteeze For Sale: T4R Items 0 07-06-2011 08:27 AM
Replacement Air Filter Cutupsum 3rd gen T4Rs 39 11-20-2005 09:43 PM
'96 Fuel Filter Replacement Wynndi Problems & Warranty Issues 2 10-11-2005 08:11 PM
TRD Replacement Air Filter Koz Engines / Suspension / Wheels / Tires / Audio / Accessories 18 04-29-2005 03:47 PM
