11-15-2021, 08:32 PM
Stalling at red lights
So my daughters '00 4Runner stalled twice tonight when she stopped at red lights. I guess tomorrow is diagnosis time, thought I'd ask you guys what I should be looking for as I start my investigation.
Basics:
300K
Scheduled maintenance
No idiot light on
Starts and Drives typically until tonight
It is now below 50
"Family and God - that is what's important. Money, cars, those are things that come and go."
11-15-2021, 08:54 PM
When was last time the MAF, IAC and intake was cleaned? Most likely the issue lies there. If it persists then move onto new plugs/wires. Luck.
11-15-2021, 09:18 PM
Basics:
300K
No idiot light on
It is now below 50
A dirty Maf and, or IAC would be my first guess.
11-16-2021, 09:54 AM
Yeah, I thought those might be the issue as well, cleaned 'em before, but it's been a while. Question: when I clean them I also run some seafoam through the motor via the brake booster vac line. That also something you do? If so, should I do the MAF/IAC pre or post foam? I think I always did post, but I also wondered when I did it. Thanks!
11-16-2021, 10:13 AM
Real Name: Patrick
Real Name: Patrick
Seafoam or any other engine cleaner through the brake booster vacuum hose will be after MAF and IAC sensors so it will not matter
11-16-2021, 10:14 AM
I don't think it would matter if you seafoam before or after. Seafoam will clean the carbon buildup in the system.
11-16-2021, 05:06 PM
Real Name: Blair
Real Name: Blair
I have a intermittent very-low idle (380-500s) for a couple mins at startup and occasionally at the first few stops in the morning. I always warm up to at least 150 degrees if not the full 185 in the AM, but idle can still be iffy for a few miles until it settles to a healthy range. Been getting very dusty and dirty over the last year (sprayed down the MAF about a year ago). Going to look into the TB, IAC valve and MAF cleanup, soon, myself.
258K - Y2K/E - Clock still works
11-16-2021, 08:05 PM
Stalled as she came to a stop or after stopping while idling?
If it stopped right at or just before stopping, it could also be a transmission issue.
I'd start with all the standard diagnosis things - check for cracks or leaks in the intake, chewed wires or other things out of place. Check if it idles/runs right during other operating conditions (non-car people don't often notice little issues before they become big issues).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
11-17-2021, 03:12 PM
My 2000 did the same thing a for a bit and after looking into most of the basics it ended up being the grd to body wires/connection right by the engine bay fuse block... probably not ur issue but checking the grds as others have stated wouldn't hurt, coming to a stop transferred enough energy into the connection to break said grd connection and would reconnect after coming to a full stop.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
