Old 11-16-2021, 02:19 PM #1
psyduck psyduck is offline
psyduck is on a distinguished road
About to order parts to do valve cover gaskets, are OEM parts necessary?
Found an older guide that had all the part numbers listed. I've seen suggestions to make sure all parts are OEM. After pricing everything out the total comes to about $220 (mostly coming from the gaskets themselves ($35 each). Does this seem like a good plan or are non-oem parts fine? Just bought the truck with 205k miles on it and theres a small leak that is getting all over my steering column and bell housing.
Also I can't do more than change oil and brakes on my vehicles so I received a quote from a local mechanic at $300 just for the labor. Does this seem right?
About to order parts to do valve cover gaskets, are OEM parts necessary?-screenshot-2021-11-16-13-13-14-png
psyduck is offline   Reply With QuoteReply With Quote
Old 11-16-2021, 02:27 PM #2
DoctorPopcorn's Avatar
DoctorPopcorn DoctorPopcorn is offline
Real Name: Tyler
DoctorPopcorn is on a distinguished road
Real Name: Tyler
This checks out from my list back in 2019. Nice work! The only thing I'd add would be FIPG gasket maker. I bought OEM, but another gasket maker would probably be fine, too.
1. Valve cover gaskets - Part #11213-62020 - 2 Total
2. Spark Plug Tube gaskets - Part #11193-16010 - 6 Total
3. Intake Plenum Gaskets - Part #17176-62040 - 2 Total
4. Washer Seals - Part #90210-05007 - 16 Total
5. Camshaft Plugs - Part #11188-62010 - 2 Total - order
6. Halfmoon Plugs - Part #11183-62010 - 4 Total - order
7. PCV Valve Grommet - Part #90480-18001 - 1 Total - order
8. Toyota FIPG seal packing - Part #00295-00103 - 1 Tube
Edit: $300 seems pretty fair for labor for this job. Took me a weekend doing it my first time, taking my precious time.
'98 Limited 4X4 320K (summer truck): OME/5100 lift, LT235/85/16 AT3W WPs, supporting mods, many trails, on 3rd rear diff. Rust.
'05 V8 Sport 4WD 250K (DD, was hoping for pavement princess, turned out to be a work horse): IronMan 4X4 Nitro Gas Stage 2: 2.5" 0-110 lb front, 3" 440-880 lb rear. Sway bar(s). LT255/80/17 Falken AT3Ws. URD Y pipe, Slyfox75 AIP Bypass. Also rust.
DoctorPopcorn is offline   Reply With QuoteReply With Quote
Old 11-16-2021, 02:45 PM #3
Great! Yeah I would definitely destroy my vehicle if I attempted this. I'm sure I would break or lose something or not be able to put it back together. I would attempt it with someone that knew what they were doing, but that's not an option unfortunately.
Old 11-16-2021, 03:44 PM #4
lockedlex's Avatar
lockedlex lockedlex is offline
lockedlex will become famous soon enough
lockedlex's Avatar
This is great timing as I was just going to order parts so I can do this job as well, thanks for compiling the list. I'm going to go with OEM since they lasted 20 years (so sticking with OEM on this one).
I will say that's a fair price.
While I'm in there, I'm also planning to change my spark plugs and S/C pulley belt.
Is there anything else (like ignition coils, etc) that I should replace as preventative maint? Money isn't really an issue, I just can't be out on a trail and have something fail from that area, esp. if I'm already going to be working there.
Thanks!
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
lockedlex is offline   Reply With QuoteReply With Quote
Old 11-16-2021, 03:56 PM #5
AJPuleo23's Avatar
AJPuleo23 AJPuleo23 is offline
AJPuleo23 will become famous soon enough
AJPuleo23's Avatar
Having dug pretty far into mine over the last 1.5 years and replacing all different kinds of components, it does make you think about how good the OEM parts are/were.
Not saying anything anyone hasn't already said on this forum, but I think the general consensus is, if its not OEM for the large majority of parts then its not going on the 4R. LBJ's and Timing belt components to be more specific.
So in my opinion, you're better off getting the OEM parts. Even if you're spending a little more coin than the other aftermarket stuff.
Having done this job twice recently (I over torqued and cracked my VC) I'd say it can be done in 2-3 hours. So IMO if you're paying a mechanic to do it for you, the $300 quote is not crazy.
If you're handy with a wrench I will say that the amount of outlets on here (just don't find the FSM article in a jam where the torque values are in ft lbs and not inch lbs LOL), and Timmy's youtube channel are great for DIY'ing it and saving the coin. Especially with common jobs like the VCG's.
2001 SR5 | 275K+ | 3" Toytec Ultimate Coils | SPC UCA's | MotegiMR150 17x8.5 + Yoko Geo 295/70/R17 | 4Xi full drivetrain skids | OCD sway bar links F&R | Powerstop TBU | Opt OR Upper & Lower rear arms | MF Overland Exhaust | Retrofit LEDs | Vivid Lumen Fogs | Full Prinsu Rack | Front bumper retrofit/fat lip delete
1983 Pickup SR5 | 93K | LCE Street Headers | 31x10.5 BFG K02's, Full Desmog and Otherwise Original
1981 Pickup SR5 longbed | 142K |
AJPuleo23 is offline   Reply With QuoteReply With Quote
Old 11-16-2021, 04:05 PM #6
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
couple of things. I would seafoam the engine and intake first. i would also get the gasket that fits the oil fill cap...it is brittle, leaks..and looks like its part of the unit but it is a gasket. id also get the throttle body gasket and the ICV gasket. I did not see a new pcv valve listed.. while throttle body is out take it apart and clean the ICV valve correctly. the plastic loom cover under the driver side gets very brittle and may brake apart on you. i wrapped my wires in "rescue tape". this would also be a good time for new plugs and wires. if it can sit overnight after putting on the new valve cover gaskets. go back and recheck the attachement bolts of valve covers. I did on one of mine...and they took more torque. speaking fo torque....correctly torque the valve covers down. they will snap if you dont and on the forums....aftermarket valve covers are junk.
As far as using aftermarket....i have had no problem with quality aftermarket on my past .2 vlave cover jobs...but i never owned the previous two over 20 k. ( totaled one and sold other it was a POS) so cant speak of longevity of aftermarket on these parts. my current one got new yota with previous owner about 35k agoaccording to receipts that came with rig.
my first I used Oshino....supposedly origally supplier to yota...but cant find again....the 2nd i went with napa mostly cause i was in a hurry and did not want to order....and most napa parts have worked good for me. but when its critical or internal i go yota
Old 11-16-2021, 06:48 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I done 1 a few months ago. I used all OEM parts did the PCV valve and the throttle body gaskets as well. I went off of Tims part list for the project and I have to do another engine here at some point.
Parts needed for replacing Valve cover gaskets V6 3rd gen
*Throttle Body Gasket #22271-62040
*Intake Plenum Gaskets #17176-62040 - (Need 2)
*Valve Cover Gaskets #11213-62020 - (Need 2)
*PCV Valve #12204-62010
*PCV Grommet #90480-18001
*Valve Cover Bolt Washers #90210-05007 - (Need 16)
*Camshaft Plugs #11188-62010 - (Need 2)
*Toyota FIPG #00295-00103
*Spark Plug Tube Seals #11193-70010 - (Need 6)
I also changed my radiator main hoses as well they needed replaced.
*Hose Radiator inlet #1657162070 (Need 1)
*Hose Radiator No 2 #1657262090 (Need 1)
Hope this helps and confirms parts.
Old 11-16-2021, 09:06 PM #8
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
If not doing the work yourself and sending off to a local mechanic I would make sure he’s familiar with doing this particular job as there are lots of opportunities to screw things up.
It’s several hours of work if doing a thorough job and replacing all the parts that others have suggested.
If not careful and done by someone who is rushing through it you can have more oil leaks than before the replacement.
I went with all OEM parts as I wanted to make sure I used the best quality parts available as I didn’t want any problems. The originals lasted nearly 20 years in my case so that speaks volumes.
Best of luck, nothing beats a clean and dry engine bay!
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 11-16-2021, 10:50 PM #9
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I went with the Fel-Pro gasket and its still holding up 3 years later. This job is a little on the tough side if you don't wrench often. Get prepared to fight the driver side cover It's not a super hard job though - it can be done in 1 day. Good luck.
2000 4Runner Limited 4x4 V6
Old 11-17-2021, 04:15 PM #10
nissanh nissanh is offline
OEM OEM.. YEs, Yes...
IMPORTANT: Take each bolt or nut you remove off the intake manifold as you dismantle the intake manifold. COVER The INTAKE ports and MAKE 100% sure you are NOT dropping anything into the engine.
I had aftermarket valve cover seals and those lasted less than 8000 miles and started leaking again. Stay with all OEM!
Here is a tip. Use Toyota FIPG. Apply a small film to the bottom side of the gasket towards the exhaust manifolds. This will keep oil in even in case the bolts get loose. I didn't do this to mine and is still dry. but did this to my friends 03 Taco's valve covers.
Toyota FIPG has a long shelf life (more than a year) and won't harden if capped and stored in a ziplock bag.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 11-23-2021, 04:57 PM #11
yotamonkey yotamonkey is offline
yotamonkey is on a distinguished road
As someone once said on here, there's a reason OEM stuff has lasted this long, so when I'm replacing worn out parts, I don't go cheap.
yotamonkey is offline   Reply With QuoteReply With Quote
gaskets , oem , parts , small , valve
Best Valve Cover Gaskets 3.4L? BoomerBob 3rd gen T4Rs 48 05-07-2023 12:16 PM
2002 Sport: About to order parts for Tundra Brake Upgrade. Please clarify parts Rancho5 3rd gen T4Rs 5 05-24-2020 07:45 PM
Any other gaskets I should replace when doing to valve cover gaskets? michaelreed 4th Gen T4Rs 0 07-23-2013 09:08 AM
Parts list for Injector replacement and Valve cover gaskets Bearded Cabbage 3rd gen T4Rs 15 03-18-2013 05:55 PM
DIY Valve Cover Gaskets MHartley Classic T4Rs 7 01-16-2009 04:56 AM
